spacer for use of s12w - where to buy and how much?
FWIW: You can also use the s12+8 caliper from the 1986 (only 1986) Toyota 4x4 PU. Use the same spacer for the s12w, Ross @ www.modernmotorsports.com has them, and the same 84-85 NA Z31 rotor. This gives you a 4piston setup, albiet smaller secondary piston, but weighs a little less and is more than effective. BTW the 86 toy 4x4 caliper is cheaper including core charge than the later ones if cost is a concern, and Axxis Metal Master pads are available for this caliper.
  • Who's Online   1 Member, 0 Anonymous, 1,092 Guests (See full list)
