pastor.rev.it Posted June 9, 2006 Share #1 Posted June 9, 2006 the car is a 72z with a 280 engine.I have electronic ignition in the car now, and am adding a msd 6al box with a blaster 2 coil.the challenge is in know how to hook it up to keep the old tach functioning.MSD tech support suggested a 8910 tach adapter and sent me a diagram showing how to hook it up.Does this thing work?Any suggestions?thanksjohn Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/ Share on other sites More sharing options...
Arne Posted June 9, 2006 Share #2 Posted June 9, 2006 First, notice that you posted this in the 240K forum, not the 240Z forum.Second, there have been lots of threads on this subject. You might want to try a search, I searched for 'msd 6al' and got these relevant threads:http://classiczcars.com/forums/showthread.php?t=15896&highlight=msd+6alhttp://classiczcars.com/forums/showthread.php?t=14129&highlight=msd+6alhttp://classiczcars.com/forums/showthread.php?t=11906&highlight=msd+6alhttp://classiczcars.com/forums/showthread.php?t=21287&highlight=msd+6alThere is also a write-up in the Technical articles section as well:http://classiczcars.com/forums/showthread.php?t=13085 Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/#findComment-170538 Share on other sites More sharing options...
pastor.rev.it Posted June 9, 2006 Author Share #3 Posted June 9, 2006 thanks I will get right to them for a read.john Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/#findComment-170569 Share on other sites More sharing options...
Dtsnlvrs Posted June 10, 2006 Share #4 Posted June 10, 2006 If wired in correctly, the tach adapter works like a charm, it even smoothes out the tach pulses, so a previously erratic tach will now function beautifuly. Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/#findComment-170610 Share on other sites More sharing options...
The C110 Posted June 11, 2006 Share #5 Posted June 11, 2006 Its really not that hard to put this sort of thing in the Z section, considering it makes up more that 75% of the forums... Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/#findComment-170700 Share on other sites More sharing options...
pastor.rev.it Posted June 14, 2006 Author Share #6 Posted June 14, 2006 Thanks for the help.first posting, unaware of the classification distinctions. Link to comment https://www.classiczcars.com/topic/20354-help-with-msd-ignition/#findComment-171021 Share on other sites More sharing options...
