Site going down soon for upgrades ×
Buy a 280 radiator . I just installed one in my 240 and it is a three core instead of two , also it is longer . My 240 radiator has different shaped top tank than the 280 so I needed to lower it 2'' to clear the hood . You won't have that problem . I just mention it for those with 240 Z . GARY
Hi Mike, another option would be to take your radiator to a good radiator shop and have them repair it. It depends on the damage, I guess, but a good shop should be able to re-core it and replace the tanks.
If you get a used radiator from a salvage yard, it would be a good idea to take it to a radiator shop and have it rodded out and tested. The shop can also re-spray it so it will look new.
