Everyone has said the front tockico springs for 240-Z's are progressive. Look at the springs on this ebay listing. They dont really look progressive. Are they???
http://cgi.ebay.com/ebaymotors/TOKICO-HP-SHOCKS-SPRINGS-NISSAN-240Z-70-74_W0QQcmdZViewItemQQcategoryZ33590QQihZ019QQitemZ8075699988
The ones in the picture are not for a 240Z. My understanding is that they do not make a non-progressive front spring. I suppose you might be able to round up the rear 240 springs and use them in the front with the rear 280 springs in the rear. That would be a little stiffer than their normal spring package but still should work well on the street. Arizona Z Car also sells linear springs that are 180/200 in lbs front and rear.
You could also call Tokico to find out.
Are you thinking of Eibach? Tokico's springs are 180 lbs/in frt and 200 lbs/in rear linear rate.
This is just plain ol wrong from every thread I've seen on the subject.
OK well one of our members has posted his tockicos on ebay, and they dont appear to be progressives, or do they???
If they're Tokicos, they're progressive in the front. They might not be as progressive as Eibachs with the coils pretty much bound for the first 1/4 of the spring length.
You're probably only going to buy springs once. You might want to search "tokico" over at hybridz.org. I've seen probably 10 different threads on this particular subject over there. Here is probably the best one: http://forums.hybridz.org/showthread.php?t=94933
Hi guys, if you look at the picture, the springs dont look like progressive wound springs. When I had them in the car the ride was stiff and the car didnt drop the 1" that is advertised. In the Motorsport catalog (where I bought them) the only advertised progressives are the Eibach. Nothing is said about the Tokicos being progressive. I'm trying to sell these because I went with Courtesy Nissan OEM springs.
It sounds like the Tokico 240Z front spring might be progressive and their 280Z front spring is not. My 280 Tokico springs are not progressive and have a 5022-F P/N. The P/N in the HybridZ thread is 5020-F. The numbers I quoted were for 280 F/R, not 240. My bad. Here is a pic of my springs. As you can see, they are linear, not progressive.
Are progressive springs wound with a tight layer and a layer with more length? The ones I have for the 240z look like Jeffs. They have 5020 on the spring. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8076848008&sspagename=STRK%3AMESE%3AIT
Some are wound tighter, some taper the wire size down, some are shaped like a beehive. The thing about the Tokicos for the 240 is a lot of people don't think they're progressive when they just look at the spring. Once it's on, they're thinking the spring is broken because the first couple coils are almost bound. I'm not sure if they're wound tighter or the wire is tapered, but I'd guess the latter based on the threads I've seen.
I don't know about the 280 springs, but the 240s are progressive in front according to Tokico. Someone should call them and find out for sure about the 280 springs.
  • Who's Online   0 Members, 0 Anonymous, 1,608 Guests (See full list)
