Hello, I'm new to these boards, but not so new to 280z's. I currently own a 1978 280z that the tail lights all of a sudden will not turn off. This problem just arose. I drive the car maybe once a week. I had to disconnect the battery terminal to disable power. Probably could have just removed a fuse but oh well. Any pointers, any ideas where I should start first. All other lights work fine.
https://www.classiczcars.com/topic/20553-tail-lights-always-on/
Just the brake lights or the brake lights, running lights and turn signals?
Does it effect the back up lights?
If it's just the brake lights, you might have a problem with the switch that contacts the brake lever under the dash. You might want to clarify for the more experienced members and check that switch while you're at it.
  • Who's Online   1 Member, 0 Anonymous, 1,431 Guests (See full list)
