Rolf,
Just to clarify, are these the braided hoses, or the rigid pipes that are mounted to the car body? If these are the braided hoses, I think the longer ones go on the rear. My reasoning- the front mounting points for the flexi pipes (to the car) are basiclly just behind the front struts, while the rears are in front of the struts and futher away. The flexi pipes at the rear have to be a longer length, as they are futher forward. Also, the flexi mounting points fit about a 1/3 up the strut, while the rears have to go all the way down to the hub. This is probably long winded but I've tried.....
Cheers
Ian
https://www.classiczcars.com/topic/20596-brake-lines/#findComment-172739
Thanks Rip260Z (Ian)
you are right, I write about the braided hoses. At first I argued like you but than I saw that by turning the steering the distance between the fixing points becomes wider or very narrow and the wheels also have to move up and down at the same time when driving. That made me sceptic, so I asked my question.
Rolf
https://www.classiczcars.com/topic/20596-brake-lines/#findComment-172741
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
