new to this forum but post a lot on the VTXOA, Arkansas forum. http://www.vtxoa.com/forums/viewforum.php?f=15&sid=611674767a25aca3bed3c6429e5f26ab I have a 280Z which I am in the process of changing from FI to carbs. I have all the components but I'm having trouble setting up the linkage... I need some help here.... any advise or direction would be appreciated.. I do have shop manuals for the 240, 260 and 280Z cars as well as a Haynes..... none of these are specific to the linkage.... HellllllP thanks Bud
https://www.classiczcars.com/topic/20597-good-morning-im/
Firstly, welcome to the site. I'm more versed at fixing EFI that swapping it to carbs but at least one of the other members has done it and maybe this post will help.
http://classiczcars.com/forums/showpost.php?p=149555&postcount=6
That would be me, among others as well. You didn't mention what carbs and manifolds you are swapping to. Knowing this will help us point you in the right direction.
https://www.classiczcars.com/topic/20597-good-morning-im/#findComment-172775
..........PS. It looks a lot better with out FI!:)
Hey, I like the look of the EFI system. But what I like even more is that it doesn't get out of adjustment once everything's right. I haven't had to deal with any EFI problems on either car in almost two years.:)
https://www.classiczcars.com/topic/20597-good-morning-im/#findComment-172817
