andrewgore Posted June 30, 2006 Share #1 Posted June 30, 2006 My brother and I an effort to simplify our 280z'z wiring have removed most of the stock ignition parts. We have replaced them with an MSD6a, 8920, Mallory coil, and the stock magnetic pickup that came on our 77 280z.We have the fuel injector pulse wire hooked up via the blue line.We have the smaller gauge red line from the MSD going to the ignition panel we are using.We have the smaller gauge red line from the 8920 going to the ignition panel we are using.We basically have the stock key in the ignition and it’s always on wired up and away. We use a master on off switch because it’s a race car so we do not have to have the key functioning in any way.Here is the problem the car will stay running if the ignition stays on. As soon as you kill the starter the car dies. What circuit don’t we have fulltime power too?Grr this is frustrating. I have the wiring diagram, and I have everything laid out in front of me.Thanks in advance for any help given to this subject. The person(s) who come up with a solution get a free 12oz bag of coffee from my company Simple-Coffee.comThanks,Josh Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/ Share on other sites More sharing options...
golgo13 Posted June 30, 2006 Share #2 Posted June 30, 2006 Hello. You would need to connect together the two wires that used to hook up to stock coil resister to make a circuit loop. Without these two wires hooked up (I think they are both black but dont remember), you can fire up the car but wont idle (due to un-looped circuit). Thats why when the ignition is at "Start" position the car starts like you said but as soon as you release the key it dies. Hope it helps. Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-172884 Share on other sites More sharing options...
andrewgore Posted June 30, 2006 Author Share #3 Posted June 30, 2006 Hello. You would need to connect together the two wires that used to hook up to stock coil resister to make a circuit loop. Without these two wires hooked up (I think they are both black but dont remember), you can fire up the car but wont idle (due to un-looped circuit). Thats why when the ignition is at "Start" position the car starts like you said but as soon as you release the key it dies. Hope it helps.Thank you so much PM me your address if you want some coffee check our website pick one out.Josh Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-172885 Share on other sites More sharing options...
andrewgore Posted June 30, 2006 Author Share #4 Posted June 30, 2006 Ok, The wires that connect to the resistor by the coil are as follows: white\black from (or possibly black\white) + coil to resistor blue - coil to "junction post" on resistor black\white on far end of resistor up to ignition Black\blue center resistor to condensor black\blue center resistor to ignition. Are we connecting the two black\blue wires there? Also, what is the little condensor deal? Looks like it just goes to a ground, is it the little item that looks like the coil deal from a power inverter? Thanks for the help. Very much appreciated Andrew edit: , my brother postd on his computer before i could on mine. thanks again though Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-172886 Share on other sites More sharing options...
joshuagore Posted July 1, 2006 Share #5 Posted July 1, 2006 Any thoughts\ideas here? We're looking at how all the wiring is hooked up at the ignition switch right now as another possible problem area. Too bad we cant just got MS in the ITS class we're in. Life would be easy. Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-172950 Share on other sites More sharing options...
andrewgore Posted July 2, 2006 Author Share #6 Posted July 2, 2006 Ok so we replaced the starter after basically killing it from all the testing.We then rewired the MSD based upon information on this forum and the directions from the MSD site.I am still confused it wont start unless the starter is engaged. So if the starter is engaged it works fine.Grr frustrating. Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-173051 Share on other sites More sharing options...
andrewgore Posted July 5, 2006 Author Share #7 Posted July 5, 2006 The 8920 will not produce the right signal needed to send to the ECU on a 77 280z with the magnetic pickup.The 8910 despite the advice from MSD and from search's on this forum WILL work if put inline with the coil wire from the MSD 6a. So red wire on the 8910 goes to the orange coil wire. White wire on the 8910 goes to the blue wire that runs to the ecu.If anyone has any questions about wiring a 77 280z up without using the transistor ignition AT ALL. Please let me know! I will do my best to helpJosh+Andrew Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-173503 Share on other sites More sharing options...
jmortensen Posted July 5, 2006 Share #8 Posted July 5, 2006 If anyone has any questions about wiring a 77 280z up without using the transistor ignition AT ALL. Please let me know! I will do my best to helpYou can take the signal wires from the distributor and run them to the Magnetic Pickup pigtail with the violet and green wire connector. Then you can wire it just like the diagram at the top of page 11 in the manual. RED + battery, BLACK - battery, orange + coil, black - coil, red switched power, distributor wires to the violet and green. Completely eliminates the factory module, which I believe was big and bulky and located inside the car IIRC. Should work just fine. Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-173507 Share on other sites More sharing options...
elementalvoid Posted June 10, 2008 Share #9 Posted June 10, 2008 You can take the signal wires from the distributor and run them to the Magnetic Pickup pigtail with the violet and green wire connector. Then you can wire it just like the diagram at the top of page 11 in the manual. RED + battery, BLACK - battery, orange + coil, black - coil, red switched power, distributor wires to the violet and green. Completely eliminates the factory module, which I believe was big and bulky and located inside the car IIRC. Should work just fine.I'm going to dig up this topic even though it is ancient.This doesn't work for me.I've got a '77 280Z and I wired it exactly as you and the manual say. I'm using the magnetic pickup from my distributor, battery + and - are connected, small red wire has +12V ignition source, and coil + and - are connected. The white wire is not used.Now for the problem... It won't stay running. It will start up, then sputters out right away.Any suggestions? Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-250295 Share on other sites More sharing options...
Clark Rush Posted March 27, 2015 Share #10 Posted March 27, 2015 msd6a wired with 8920 tach adapt. to my 280zx power 240Z fire's ,but will not run (Idle)white tach-output not installed,do I have to connect this so the ecu can trigger & run EFI. Spark yes! Fuel & spark in Start mod, yes! ! fuel & spark in run mod,yes. I have removed E12-80 ign.mod.Trying to -get engine to run only on MSD ignition Real world help ???? mag pick-up Green & red Msd violet & green. GRN 2 RED, VIOLET 2 GREEN polarity correct YES ? Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-466521 Share on other sites More sharing options...
Zed Head Posted March 27, 2015 Share #11 Posted March 27, 2015 msd6a wired with 8920 tach adapt. to my 280zx power 240Z fire's ,but will not run (Idle)white tach-output not installed,do I have to connect this so the ecu can trigger & run EFI. Spark yes! Fuel & spark in Start mod, yes! ! fuel & spark in run mod,yes. I have removed E12-80 ign.mod.Trying to -get engine to run only on MSD ignition Real world help ???? mag pick-up Green & red Msd violet & green. GRN 2 RED, VIOLET 2 GREEN polarity correct YES ?Start a new thread and fill the first post with complete sentences. Yes? Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-466524 Share on other sites More sharing options...
Clark Rush Posted March 27, 2015 Share #12 Posted March 27, 2015 I installed MSD 6A unit & 8920 tach adapt To my 240z with 79 280zx engine. as per instructions. the white tach output lead from 8920 is not hooked up.car has factory tach,but is dead.Engine fires, but won't run (idle) do i have the wrong tach adapter,or should i run system thur stk.ignition E12-80.Replaced 3 of these in the last 4 months' Car ran great for 3+ years. Link to comment https://www.classiczcars.com/topic/20612-another-msd-problem/#findComment-466526 Share on other sites More sharing options...
