mars23z Posted July 7, 2006 Share #1 Posted July 7, 2006 I was wondering if the alt from the zx is the best upgrade for a 260z. I can buy a 60 amp from advance auto that is made for the 260z but was wondering if that is the biggest or best for my mostly stock 260zThanks Chris Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/ Share on other sites More sharing options...
280z1975 Posted July 7, 2006 Share #2 Posted July 7, 2006 Try this one:http://www.datsunstore.com/product_info.php/pName/105amp-high-output-alternator Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173773 Share on other sites More sharing options...
SteveJ Posted July 7, 2006 Share #3 Posted July 7, 2006 I was wondering if the alt from the zx is the best upgrade for a 260z. I can buy a 60 amp from advance auto that is made for the 260z but was wondering if that is the biggest or best for my mostly stock 260zThanks ChrisThe alternator from the Z31, the 280ZX, and 78 280Z will work. HOWEVER, all alternators for Z cars 78 and later are internally regulated. That means you will need to bypass your external regulator or face some big-time issues with your charging system. You'll also need to install a diode on the alternator to prevent feedback issues that will cause run-onBeen there.Done that.Got the T-shirt. Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173774 Share on other sites More sharing options...
Arne Posted July 7, 2006 Share #4 Posted July 7, 2006 The alternator from the Z31, the 280ZX, and 78 280Z will work. HOWEVER, all alternators for Z cars 78 and later are internally regulated. That means you will need to bypass your external regulator or face some big-time issues with your charging system. You'll also need to install a diode on the alternator to prevent feedback issues that will cause run-onBeen there.Done that.Got the T-shirt.You do have to by-pass the external regulator, but I'm under the impression that you might not need the diode on a 260Z, only 240Zs. Could be wrong though... Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173775 Share on other sites More sharing options...
Montezuma Posted July 7, 2006 Share #5 Posted July 7, 2006 Try this one:http://www.datsunstore.com/product_info.php/pName/105amp-high-output-alternatorNice website....A little pricey..... Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173778 Share on other sites More sharing options...
SteveJ Posted July 7, 2006 Share #6 Posted July 7, 2006 You do have to by-pass the external regulator, but I'm under the impression that you might not need the diode on a 260Z, only 240Zs. Could be wrong though...You could also be right. I don't know what causes the issue. I don't think that it's because of the presence/absence of an electronic ignition. I have a Crane electronic ignition in my 240 and experienced the run-on.Anyway, the diode is cheap. It's handy to have in case run-on is an issue. Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173779 Share on other sites More sharing options...
mars23z Posted July 7, 2006 Author Share #7 Posted July 7, 2006 What about a 50 or 60amp alt is that better than stock? Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173780 Share on other sites More sharing options...
SteveJ Posted July 7, 2006 Share #8 Posted July 7, 2006 What about a 50 or 60amp alt is that better than stock?As far as I know, it only truly matters if one is adding electical/electronic components. Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173781 Share on other sites More sharing options...
mars23z Posted July 7, 2006 Author Share #9 Posted July 7, 2006 I ask because my turn signals are slow and at a stop they sometimes don't work at all they work fine when i am moving Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173785 Share on other sites More sharing options...
weasel240z Posted July 7, 2006 Share #10 Posted July 7, 2006 check out www.zspecialties.com 1 wire hook up . awesome cut in so no more dimming lights. Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173786 Share on other sites More sharing options...
SteveJ Posted July 7, 2006 Share #11 Posted July 7, 2006 I ask because my turn signals are slow and at a stop they sometimes don't work at all they work fine when i am movingThat's an issue of resistance probably from a build-up of corrosion. Clean your switch, connectors, and bulb sockets.Another solution might be to change out the flasher unit if you haven't done that. Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173788 Share on other sites More sharing options...
mars23z Posted July 7, 2006 Author Share #12 Posted July 7, 2006 That looks awsome but for $199 i think I'll go with a 50 amp for $30 Link to comment https://www.classiczcars.com/topic/20706-alternator-upgrades/#findComment-173790 Share on other sites More sharing options...
