hi all
have changed over from my
2.8l nissan standard inlet manifold,standard 50m throttle body and extractors
ems stinger computer
new ones replaced are
2.8 nissan naps inlet manifold.65m throttle body of a ford and stewart wilkins extractors
my problem is when i started the car tonight it reved to around 4,500 and would not idle back down
tried the adjuster screw but that did nothing
what would you guys suggest i do
thought that i may disconnect the computer so it could reset itself
but any help would be appreciated
thank you
robert
https://www.classiczcars.com/topic/20750-efi-throttle-body-help/
Have you changed the ECU as well? If not, check all sensors, I know this sounds stupid but I had endless probs withmy car because the connections to the thermotime switch and temp sender were bad.
Cleaned them up (both the terminals and the plugs) and it was all good.
Only other things I can think of are the throttle position switch and maybe the air flow meter (if you're still using it)??
So did has the NAPS manifold made the difference you were looking for? Could you send me a pic of your setup so I can see how the my old manifold now looks - I have not got to the point of using the brackets that I got as part of deal/purchase/sale/swap thing we did last year
hi
have changed the gearbox and diff from a 240k
stewart supplied both so it has not been on the road for a few weeks
fitted the longer extractors from stewart wilkins
your manifold and throttle body
running a falcon cable for accelerator
it does seem to rev up a lot quicker than before
its going to the muffler shop monday
for 2 1/4 inch exhaust
then up to stewart for the tuning and dyno
hope i get to that magic 100kw at the wheels
when i got 90kw out of it it had only done 1,000k
it has loosened up i bit now
by the way did you end up getting the manifold with the six throttle bodies from melbourne they looked unreal but could not afford a justifer the price
but if i had the money they would be on soon as i could get them
thank
robert
