Reverse Switch - Lost all wires but one (however I know switch works).
I have located the harness and I know the appropriate wires (red and red/black) to connect to the switch. My question is what wires on the swtich do each of the harness wires connect to?
The reverse switch has one remaining wire with a bullet connector. Does it connect to the red or the red/black wire?
Thanks.
You're missing the wire to connect to the Red wire. Since it's a switch, the wire you have goes to either the Red or the Red/Black depending on which one has the corresponding bullet connector (male / female) but you HAVE to have the other wire for it to do it's job.
The switch closes the circuit between the Red AND the Red/Black to light the Reverse Lamps.
Since I don't recall the 72's as having a Neutral Interlock, I would presume that your switch has lost one wire. Either replace the switch or repair it and add the wire it needs.
Hope this helps
Enrique
Enrique, I understand that I need a second wire on my switch, but I need to know which wire from the harness (red or red/black) connects to the remaining wire with the male bullet plug on the switch.
Secondly, my red and red/black wires in the harness are missing their connections. If one of them had a connection, I would be able to determine what wire connects where.
You are correct in your recollection, 72's do not have a Neutral Interlock.
Thank you for the help.
Curtis240z, thank you!
A quick question for you, is that the typical protocol for determining male/female electrical connections? How would a male connector (where it should be female) short to ground?
Again, thank you.
You know, if the switch on a '72 is the same as on my early '71, both connectors may be the same. Since the switch simply completes the circuit, it doesn't matter which wire is connected to which. When I did the transmission swap on my car I recall this being the case, both pigtails on the switch were black and both had male bullets, IIRC.
