A heavy duty flasher will cycle slower and the light duty will be much faster. Much depends on the load on the circuit. I doubt that the heavy duty one will harm anything but once a min is not much of a turn signal.
You might have pulled the Hazard Relay as opposed to the Flasher Relay. They're both Flasher Relays but the Hazard one is a heavier gauge in order to run all 4 corners at the same time. Typically this one is marked as Heavy Duty and if memory serves are predominantly Amber in color. Whereas the Silver can is for the regular Turn Signals. (This may not hold true for all flashers, just a curious observance of mine.)
Location is also an indicator. The Hazard Flasher on the early Z's is on the passenger kick panel, whereas the Turn Signal Flasher is by the Steering Column area.
While I haven't done it nor experimented with it, since the Flasher Relay relies on the current it carries to determine it's flash rate, I would think that the Hazard in the Turn Signal spot would flash very slowly. Whereas a Turn Signal in the Hazard position would flash very fast. Again, this is untried and untested, so someone else may have a better explanation.
E
mine are stacked on each other I think, at least there are two pieces for the flashing unit
I had slow signals or no signals
it was NOT the flasher
it was burned out bulbs. ALL, yes ALL the bulbs must be A OK for the flashing system to work correctly according to my experience on my 72
your milage may vary
Two pieces? I've seen it where there's an additional NOISE maker attached to the base of the flasher, but never where the flasher as a whole was comprised of two pieces.
The location of the individual flashers varied by model year. Where mine (71) are as I described above, I've seen both on the passenger kick panel, or one on each kick panel.
Usually, with the loss of one bulb filament, there will be more current through the circuit and therefore a FASTER flash rate rather than slower. At least that's been my experience, but it is interesting to note that your system flashed slower with burned out bulbs.
E
