Oh, so your talking about wind deflectors? I thought you meant that thing that you see on some cars and trucks that hangs off the front of the roof and extends about 6" or so over the front window. I'm glad that's not what you meant though you have come up with some wierd stuff in the past, but I digress. I don't think anyone actually makes or made wind deflectors for an S30 but I have seen them on a couple of Zs so they must have been modified to fit as 240ZX indicated.
https://www.classiczcars.com/topic/21119-window-visors/#findComment-177789
The only issue I see about mounting the side window deflector is that you couldn't stick it to the top of the window frame, because of the weather strip. Maybe, if it was thin enough, You could stick it on and put the weatherstrip over it.
Steven-
I think you are probably talking about the visors like the ones that go on old cars & trucks? I've never seen them on new cars & trucks.
Looks like time for some shopping.
https://www.classiczcars.com/topic/21119-window-visors/#findComment-177793
STEPHEN not Steven, it's in my signature, but again I digress. Those visors I described were on older cars and trucks but back to the deflectors. I looked to those a while back but decided that they would have to be mounted on the outer edge of the window frame with screws (no way!) or double sided tape, hard to remove and a mess to clean up. Let me know if you come up with anything better.
https://www.classiczcars.com/topic/21119-window-visors/#findComment-177795
Sorry, Stephen I have signatures off (they use up the screen.)
The only way I can think of to mount a deflector without having anything messy showing is something that goes into the indow channel and held in place by having the window up (Duh) or to clamp onto the rain gutter.
https://www.classiczcars.com/topic/21119-window-visors/#findComment-177798
  • Who's Online   2 Members, 0 Anonymous, 1,535 Guests (See full list)
