Welp... got reallllyy bored.. cleaned the car and took some pics...
Your ground clearance with that front spoiler looks worst than marginal. Is that why the bottom piece is riveted for quick replacement?
Must be impossible to drive that thing after the first snow fall ....... do you use it to clear the snow off the driveway?
440cc injectors are good up to around 400rwhp..
youll be fine even with the 370cc injectors for 300rwhp..
300rwhp is easy to achieve.. a Hybrid turbo such as a T3/T04e .. or even a Holset like me (cheap affordable version of a T3/T04e) ... and about 12psi
you can hit 300rwhp even with the stock EFI !! just need an intercooler and bigger injectors and your set.. I'm sure at 15psi the stock T3 could hit 300rwhp.
other alternatives is upgrade to the Z31 ECU or Megasquirt, SDS, Haltech etc
