I have put together a cheat sheet for all to you. Use this sheet when you need to understand when someone abbreviates a phase and you do not know what it stands for. Now my no means is this list complete. If you knwo of additional items let me know and I will update the list and replublish it for all..
If you would like this sent to you please email me with your request and what format you would like it in.
Datsun FAQ Acronym Page
DRCV distributor retard control valve
A/C air conditioning
A/F air/fuel ratio
A/T automatic transmission or transaxle
ABS antilock brake system
AC air cleaner
AC alternating current
AERA Automotive Engine Rebuilders Assn.
AFM air flow meter
AIR secondary air injection
API American Petroleum Institute
ASE Automotive Service Excellence
ATC after top center
ATDC after top dead center
ATF automatic transmission fluid
ATMC Automotive Training Managers Council
AWD all-wheel drive
B+ battery positive voltage
BARO barometric pressure
BAT battery
BHP brake horsepower
BPS barometric pressure sensor (Ford & Nissan)
BPT back-pressure transducer
BTC before top center
BTDC before top dead center
Btu British thermal units
C Celsius
CAAT Council of Advanced Automotive Trainers
CAC charge air cooler
CAFE corporate average fuel economy
CALPAK calibration pack
CARB California Air Resources Board
CAS crank angle sensor
CC catalytic converter
CC cubic centimeters
CCOT clutch cycling orifice tube
CCV canister control valve
CDI = Capacitive Discharge Ignition
CEAB cold engine air bleed
CECU central electronic control unit (Nissan)
CESS cold engine sensor switch
CFC Chlorofluorocarbons
CFI continuous fuel injection
cfm cubic feet per minute
CID cubic inch displacement
CKP crankshaft position sensor
CKP REF crankshaft reference
CL closed loop
CMP camshaft position sensor
CMP REF camshaft reference
CO carbon monoxide
CO2 carbon dioxide
COP = coil on plug
COP Coil On Plug ignition
CPP clutch pedal position
CPU central processing unit
CTOX continuous trap oxidizer
CTP closed throttle position
CTS = Coolant Temperature Sensor
CTVS choke thermal vacuum switch
DB decibels
DC direct current
DEPS digital engine position sensor
DFCO decel fuel cut-off mode
DFI direct fuel injection
DLC data link connector
DOHC dual overhead cams
DOT Department of Transportation
DTC diagnostic trouble code
DTM diagnostic test mode
DVDSV differential vacuum delay and separator valve
DVDV distributor vacuum delay valve
DVOM digital volt ohm meter
E=EFI Motor Used on the end of Motor type Eg l28E
EBC = Electronic Boost Control
EBCM electronic brake control module
EBTCM electronic brake traction control module
EC engine control
ECA electronic control assembly
ECCS Electronic Concentrated Control System (Nissan)
ECL engine coolant level
ECM engine control module
ECT engine coolant temperature
EDI(S) = Electronic Distributor less Ignition, add an "S" and it stands for System
EEPROM electronically erasable programmable read only memory chip
EFC electronic fuel control
EFE = early fuel evaporation
EFI electronic fuel injection
EGR = Exhaust Gas Re-circulation
EGR exhaust gas recalculation
EGRT EGR temperature
EI electronic ignition
EM engine modification
EMI electromagnetic interference
EOS exhaust oxygen sensor
EPA Environmental Protection Agency
EPROM erasable programmable read only memory chip
EVAP evaporative emission system
F Fahrenheit
FC fan control
FEEPROM flash electrically erasable programmable read only memory
FF flexible fuel
FI = Fuel injection
FMVSS Federal Motor Vehicle Safety Standards
FP fuel pump
FPROM flash erasable programmable read only memory
FT fuel trim
Ft.lb. foot pound
FTP federal test procedure
FUBAR F--ked Up Beyond All Repair
FWD front-wheel drive
Gal gallon
GCM governor control module
GEN generator
GND ground
GPM grams per mile
H20 water
HC hydrocarbon
HEGO heated exhaust gas oxygen sensor
Hg mercury
HO2S heated oxygen sensor
HO2S1 upstream heated oxygen sensor
HO2S2 up or downstream heated oxygen sensor
HO2S3 downstream heated oxygen sensor
HP = Horse Power
HVAC heating ventilation and air conditioning system
HVS high voltage switch
I/M inspection/maintenance
I/P instrument panel
IA intake air
IAC idle air control
IAT intake air temperature
IC = Intercooler
IC ignition control circuit
IC integrated circuit
ICM ignition control module
ID inside diameter
IFI indirect fuel injection
IFS inertia fuel shutoff
IGN ignition
IIIBDFI If it isn't broke don't fix it
IM240 inspection/maintenance 240 program
IPC instrument panel cluster
ISC idle speed control
ISO International Standards Organization
KHz kilohertz
KISS Keep It Simple Stupid!
KM kilometers
KOEC key on, engine cranking
KOEO key on, engine off
KOER key on, engine running
KPa kilopascals
KS knock sensor
KSM knock sensor module
KV kilovolts
L liters
L24=Naturally Aspirated 2.4 Liter 6 Cylinder L series Found in 240Z
L26=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z
L26E=Naturally Aspirated 2.6 Liter 6 Cylinder L series Found in 260Z
L28E=Naturally Aspirated 2.8 Liter 6 Cylinder L series Found in 280Z
L28ET=Turbo Charged 2.8 Liter 6 Cylinder L series Found in 280ZX
LB. ft. pound feet
LCA = lower control arm
LCD liquid crystal display
LED light emitting diode
LTFT long term fuel trim
MACS Mobile Air Conditioning Society
MAF = Mass Air Flow (meter/sensor)
MAF mass airflow sensor
MAMA Midwest Automotive Media Assn.
MAP manifold absolute pressure sensor
MAT manifold air temperature
MC mixture control
MDP manifold differential pressure
MFI multiport fuel injection
MIL malfunction indicator lamp
MM millimeters
MPFI multi point fuel injection
MPG miles per gallon
MPH miles per hour
MPI multi port injection
MS = Mega Squirt
MS millisecond
MSDS material safety data sheet
MSnS-E = Mega Squirt n Spark-Extra
MST manifold surface temperature
mV mill volts
MVZ manifold vacuum zone
NA = Normally Aspirated
NACAT National Assn. of College Automotive Teachers
NATEF National Automotive Technician's Education Foundation
NHTSA National Highway Traffic Safety Administration
Nm Newton meters
NOX oxides of nitrogen
NVRAM nonvolatile random access memory
O2S oxygen sensor
OBD I onboard diagnostics generation one
OBD II onboard diagnostics, second generation
OBD onboard diagnostics
OC oxidation catalyst
OD outside diameter
ODM output device monitor
OE original equipment
OEM original equipment manufacture
OHC = over head cam
OHC overhead cam
OL open loop
OS oxygen sensor
OSC oxygen sensor storage
P/B power brakes
P/N part number
PAIR pulsed secondary air injection
PCM power train control module (supercedes ECM)
PCV = Positive Crankcase Ventilation
PCV positive crankcase ventilation
PECV power enrichment control valve
PERA Production Engine Rebuilders Assn.
PNP park/neutral switch
PPM parts per million
PROM program read only memory computer chip
PS power steering
PSA pressure switch assembly
PSI pounds per square inch
PSP power steering pressure
pt. pint
PTOX periodic trap oxidizer
PVA ported vacuum advance
PVS ported vacuum switch
QS9000 Quality assurance standard for OEM part suppliers
Qt. quart
RAM random access memory
RFI radio frequency interference
RM relay module
ROM read only memory
RPM revolutions per minute
RPO regular production option
RS Supplemental Restraint System (air bag)
RWD rear-wheel drive
SAE Society of Automotive Engineers
SAP accelerator pedal
SAVM spark advance vacuum modulator
SC supecharger
SCB supercharger bypass
SDM sensing diagnostic mode
SFC = sub frame connector
SFI sequential fuel injection
SIR Supplemental Inflatable Restraint (air bag)
SOHC single overhead cam
SRDV spark retard delay valve
SRI service reminder indicator
SRT system readiness test
STFT short term fuel trim
STS Service Technicians Society
TACH tachometer
TB throttle body
TBI throtle body injection
TC rod = tension compression rod or strut rod
TC turbocharger
TCC torque converter clutch
TCCS Toyota Computer Controlled System
TCM transmission or transaxle control module
TDC top dead center
TFP throttle fluid pressure
TP throttle position
TPP throttle position potentiometer
TPS throttle position sensor
TV throttle valve
TVS thermal vacuum switch
TVV thermal vacuum valve
TWC three way caalyst
TWC+OC three way + oxidation catalytic converter
UCA = upper control arm
V volts
VAC volts alternating current
VAF vane airflow sensor
VAF volume airflow
VCM vehicle control module
VDC volts direct current
VDV vacuum delay valve
VIN vehicle identification number
VR voltage regulator
VS vehicle sensor
VSS vehicle speed sensor
WOT wide open throttle
WSS wheel speed sensor
WU-TWC warm up three way catalytic converter
Datsun FQA Acronym page.xls
https://www.classiczcars.com/topic/21239-help-for-all-of-you/
Here are a few more.
AFM Air Flow Meter
FSM Factory Service Manual
PO Previous Owner
NO Normally Open
NC Normally Closed
AAC Auxillary Air Control Valve
ERV Emergency Relief Valve
not an acronym, but still occasionally causes confusion
Dizzy-distributor
STFU = Shut The Frak Up (Thanks to Battlestar Galactica!)
NOS = New, Old Stock Term referring to an Old item that used to be a Stocking item, that was never sold originally. Most commonly refers to items still in their original packaging from years ago, or that have never been installed / used.
CZC = Classic Z Car (Club); mainly THIS site.
IZCC = Internet Z Car Club (Zhome)
E
  • Who's Online   1 Member, 0 Anonymous, 1,453 Guests (See full list)
