jfairladyz Posted September 1, 2006 Share #13 Posted September 1, 2006 the orientation in the pic is the correct orientation with the engine at TDC (#1 compression).And a quick question: if its still not running then why do think your new dizzy orientation and firing order is now correct? Not flaming you, but is there something that happened after you changed all this that led you to believe things were better afterward? Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180686 Share on other sites More sharing options...
beandip Posted September 1, 2006 Share #14 Posted September 1, 2006 Here is a thought about your timing. The base that the dist goes into and bolt to . If the one you are using is from the 240 dist. it will not work and the timing will be way off. The mounting bolt is positioned in a different place on the 240 mount than the ZX mount . If you bought a rebuilt dist. they don't come with this part. This just a thought. My ZX ignition and 240 tach work fine in my '73 . Unlike what the geocities information said. By the way that site is a wealth of information , however over the years I have found a few things that were inaccurate , but minor things . Gary Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180691 Share on other sites More sharing options...
zack_280 Posted September 1, 2006 Author Share #15 Posted September 1, 2006 jfairladyz,I think it will run but it was later last night when I got finished with it and I wanted to have a little time to work any kinks out before I fire it up. I am 99% sure it will run. I will find out today. I should have added that tidbit to my previous post. Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180705 Share on other sites More sharing options...
Ksteve Posted September 1, 2006 Share #16 Posted September 1, 2006 Zack,You've probably already noticed, it appears your radiator and your cooling fan have been in a fight. Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180738 Share on other sites More sharing options...
zack_280 Posted September 2, 2006 Author Share #17 Posted September 2, 2006 Yeah, Steve, I noticed. It was like that when I got it and it seems to cool pretty well. It ain't broke, so I ain't gonna fix it. Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180797 Share on other sites More sharing options...
zack_280 Posted September 2, 2006 Author Share #18 Posted September 2, 2006 The car fired right up this afternoon and it's running great (as far as I can tell). Thanks to everyone for your help.Zack Link to comment https://www.classiczcars.com/topic/21376-zx-dizzy-connections/?page=2#findComment-180798 Share on other sites More sharing options...
