Rust-free Floors in a Z??????
I took the seats out of my 38,000 mile 1972 240Z and decided to check out the floors a little more closely. On the surface they looked rust free due to the tars mats covering them. I carefully peeled up the mats and found some pretty heavy "surface rust", but no holes....yet. So I decided to treat them with the clear POR-15 instead of the black so that it wouldn't obsecure their actual condition. After two solid days of treating the floors with Metal Ready and scraping off as much rust as possible I put two coats of clear POR-15 on yesterday. I was amazed by the results.
I was able to carefully remove the tar mats without ripping them up and I may tack them back on the treated floors to preserve the original look and help keep the road noise down. Let me know what you think.
https://www.classiczcars.com/topic/21457-rust-free-floors-in-a-z/
are those spot welds next to the seat brackets on the floor? It almost appears as if the floors have been replaced.
PirOson - No, the floor is orignal. The two brighter silver spots on the back side of the front seat mount in the 2nd driver's side pic are due to the glare of the POR-14 around the channels that go under the brackets.
The final result looks good, but what about the underside of the floors. Are they treated with undercoating?.
They underside of the floors are treated with factory undercoating, so I am less worried about them at the moment. I will have to check them out further when I have the time, but from what I have seen the undercoating looks to be intact.
Ah, I see. I was looking at those spots exactly :)
Chris, my thought exactly. I am envious of Mikes floor pans. Saved a bunch of time(and money) on that one. Looks like his car is in great shape period. The white vinyl looks brand new. I would suspect that there is "surface rust" all inside the frame rails under the pans and that will eventually come throught the pans. I guess all you can do is inject some metal ready and then try your best to inject some por
  • Who's Online   1 Member, 0 Anonymous, 1,454 Guests (See full list)
