'71 rear hatch strut
You might be better off the change the entire hatch if the 280 hatch fits a 240. There are threaded holes in the hatch where the strut mounts and the lower brackets where the other end of the strut mounts are welded to the body.
The later hatches will fit the 240s, but don't have the rear vents that I Series 1 car came with. My car came with a 280 hatch on it when I bought it.
But it's not hard to add threaded holes, a couple of nut-serts would do it.
I have another question regarding this strut. I have a 71 and the single strut tends to tweek the hatch such that it is gapped higher on the DS.
I put a rubber bumper on the passenger side of the rear deck so it levels out the hatch.
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000164450/mediaCode-ZX/appId-100000164450/Pr-p_CATENTRY_ID:100000164450
BTW is does fit my single strut 240Z even though the description says it won't fit Nissans, maybe because we have Datsuns.
