The aft ends of the roof drip rails, have become loose, as if they were pulled off, and they seem to be twisted. Is that normal? The inner shelf flange is turned up so that thhe water can easily run underneath. I'd like to get them back on & untwisted. They don't easily twist back. I can get a pic later, but I think this may be a coimmon problem.
What's the fix?
thx
https://www.classiczcars.com/topic/21735-twisted-drip-rail-ends/
You know, I think that may be normal. I had them off when my car was painted and that flange tapers outward the last 4 inches or so but the drip rail doesn't get any thicker so it won't go on any farther than that at the end. Both of mine fit flush until they get to that point.
The reason I'm inquiring is because at a car show last summer, I was penalized because my drip rails didn't follow the body lines, or- stuck out and were twisted. :hurt:
expert judge...
Sounds like the judge didn't know Zhit!
Will
  • Who's Online   0 Members, 0 Anonymous, 1,485 Guests (See full list)
