install a volt fuel guage in Amps fuel harness
Evening everyone
Strait up question
Can I install a Volt / fuel guage ( unknown year of Z) into my 75 280Z wiring harness as plug and play?
The Volt / fuel plug is identical is identical to the Amps / fuel on the back of the guage though the wires are a different colour (scary).
It was determined in a previous Thread that this was the way to go as I do not have a shunt (none came with the car) and I have done the alternater up grade to get rid of the Voltage regulator
Yes I know there is a lot going on electrically!
Thoughts ,encouragement , solutions would all be appreciated!
Bloxman
IIRC the AMP guage main terminal wires should be connected together when it is removed...
The volt guage + should connect to the main wires the AMPS guage used and the - to ground...
Do not attempt the hook up the VOLTS guage in series the way the AMPS guage was wired...
I think a later version of the AMPS guage used a shunt under the passenger kick panel... That may change the underdash wiring significantly... use caution here...
