Chassis/Engine Ground kits
Why I ran the Motec M48 EMS on the Rusty Old Datsun it was important to get a good ground because the EMS needed it as a base reference. I was also running a 16v battery and a Bosch Motorsports 16v alternator. All it took to get a perfect ground was a #6 battery ground cable and a copper strap connecting the engine to the chassis at the alternator mount.
I jotted down a list of the connections I thought would be good to make:
1. Batt(-) -> chassis
2. Chassis -> starter (-)
3. starter (-) -> block
4. block -> head
5. block -> Alt.
6. Alt. -> Intake
7. Intake -> Dist.
8. Intake -> AFM
9. Intake -> chassis/dropping resistors
10. Drop. res. -> steering column/headlights
-The block:near the bottom; the heater hose clamp
-head: front/hoist bracket?
-Intake: middle; the EFI wires clamp or AAV valve
-AFM: Any bolt
-Drop. resistors: mounting bolt
-Steering Col.: preferably the headlamp switch bolt and/or the lighting rheostat
I still don't think 8 Ga wire would be approprite- too obvious. I'm going with 10Ga. 1000 strand wire. Not much current is involved.
thx
  • Who's Online   3 Members, 0 Anonymous, 289 Guests (See full list)
