There is alot of work involved in setting up a set of coilovers, but it is well worth the hassle. I personally recomend Ground Control, but any kit should be just fine. Gotta remember it is nothing more than a threaded sleeve and a collar. Everybody uses the same upper spring perch and you can buy anybodys springs. Do a search on these forums for more detailed info, it has been talked about alot here, and on HybridZ.org
Great Stuff from Beta Motorsports. Easiest way to get to where you want to go. Coilovers already mounted on shortened struts with a selection of insert types to choose from, plus it includes SCCA Street Prepared legal Camber Plates.
Thanks for the info I need to do some research I guess! I see a few diff. types and alot of price diff. also, I want something good but at the same time I dont want to spend more than I have to .Thanks
those look great, but the price is so high.
  • Who's Online   0 Members, 0 Anonymous, 1,583 Guests (See full list)
