Never did get it started. I was just trying to get it started so I could turn the car around in my garage in order for me to pull the motor anyway. I finaly gave up and pulled the motor from where it sits. Now have motor at Rebello Racing for total Hot Rod rebuild and I decided to go with Mallory Unilite electronic ignition distributor. Probably wont have it up an running 'till next year 'cause rest of car is heading for body and paint. Will keep you posted.
Good luck on yours.
Mark
https://www.classiczcars.com/topic/2243-i-give-up/?page=2#findComment-16847
Good luck on yours.
Mark
Well I finally solved it.
It was so fustrating that I'm posting the solution that in the unlikely event it may happen to any other poor unfortunate member.
It was all caused by the vacuum advance.
Just to clarify the situation as all zeds are different, my 260 came with a 280z/x hitachi distributer, so this may not apply to 240's or other 260's with similar symptoms.
The wire at the top of the capacitor had actually broken, even though the insulation was intact and a visible inspection showing all to be OK.
The cause of this was the vacuum advance, which, when advanced moved the capacitor against the distributor case. This over time caused stress fatigue and eventual breaking of the wire.
Very fustrating as a check for spark indicated all to be well [admitadly, the spark was weak] when cranking over but no spark when the engine starts.
MN:devious:
https://www.classiczcars.com/topic/2243-i-give-up/?page=2#findComment-17395
  • Who's Online   2 Members, 0 Anonymous, 1,227 Guests (See full list)
