More progress... not going to get it to the track this year before snow flies but next year for sure.
made 605 at 18PSI. 700 should be real easy.
605 at 18 psi 8900 rpm - YouTube
Convinced my daughter to take a ride.... she wasn't very happy afterwards ;>
rb26 260z drag car inside car - YouTube
rb26 drag 260z outside car - YouTube
  • 1 month later...
Not sure if you can call it progress but….
Removed the converter for one last attempt at a stall. Going balls to the wall with a 7+K stall and see if that helps with getting the turbo to spool.
Have lots of wiring cleaning up to do here.
Also removed ATI damper to get timing marks laser cut. Yea the old ones didn’t come with timing marks WTF???
Also redid the install on the NOS solenoids and nozzle and installed them under the manifold so I don’t have that huge mess on top. Its all underneath now!!
Before
After
Also redid some wiring behind the dash so removing the dash doesn’t involve snipping wires.
  • 2 months later...
Well i finally completed something i have been putting off forever. Wiring. its not all done BUT all i really have to do is run wires (14 to be exact) and clean up the engine harness under the dash and its done.
This is the first time time i have ever attempted something like this. Probably wont do it again either. VERY TIME CONSUMING!!!
  • 2 months later...
  • 4 months later...
  • Who's Online   2 Members, 0 Anonymous, 1,468 Guests (See full list)
