I came up with a slightly different solution to this problem. I used a plastic friendly epoxy putty and reinforced the two bosses that are used to attach the choke bracket to the console. My old bosses were broken about half-way down, so I made sure to cover the tops of the bosses and push putty into the hole.
I waited until the epoxy was dry and then drilled and tapped two new holes. I then cut the heads off of two machine screws and used them as studs. I super glued the studs into the new holes.
  • 3 months later...
  • Who's Online   2 Members, 0 Anonymous, 1,133 Guests (See full list)
