jmeti000 Posted December 19, 2006 Share #1 Posted December 19, 2006 first, will the hood from a 2x2 260z fit on a 280 coupe...and second, whats the best way to fill in rivet holes on the doors and fenders from the molding strips that used to be on them...there is no rust, just the holes..thanks,jacqui Link to comment https://www.classiczcars.com/topic/22689-couple-question/ Share on other sites More sharing options...
Ed Posted December 20, 2006 Share #2 Posted December 20, 2006 Best way is to have them welded. Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193154 Share on other sites More sharing options...
e_racer1999 Posted December 20, 2006 Share #3 Posted December 20, 2006 Best way is to have them welded.that's what i was thinking, but wouldn't the heat morph the metal? Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193171 Share on other sites More sharing options...
EScanlon Posted December 20, 2006 Share #4 Posted December 20, 2006 Like Ed says:BEST way.... MIG WeldedSecond best way...BrazedThird relatively good way .... SolderedFourth Fairly Good Way ... POR 15 Mesh with Power Mesh Backing, and filled with POR Patch on the front.Absolutely WORST way ... Bondo.Second WORST way .... Duct Tape from behind with tons of touch up paint in front.All of them require work in a body shop to finish.E Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193175 Share on other sites More sharing options...
EScanlon Posted December 20, 2006 Share #5 Posted December 20, 2006 that's what i was thinking, but wouldn't the heat morph the metal?Yes, and even if you get a very good welder that can fill the hole in one or two spot welds ... and therefore minimum heat ... the heat and spark will still burn the paint surrounding the hole. To recover from that you'll need to re-primer, re-paint and match paint or re-paint the whole fender/door.E Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193176 Share on other sites More sharing options...
jmeti000 Posted December 20, 2006 Author Share #6 Posted December 20, 2006 not to concerned about the paint at this point, its going to be completely redone anyways when this is done....so im guessin that after the holes are welded its not gonna be all smooth and flush with the rest of the sheet metal, so how do i smooth it out so it is? Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193178 Share on other sites More sharing options...
jmeti000 Posted December 20, 2006 Author Share #7 Posted December 20, 2006 oops, pushed reply to soon....... anyways, so is that the part that the body shop will hafta do? reason im askin is im tryin to get as much of it done as i can so the cost wont be quite the killer that its otherwise gonna be.. Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193179 Share on other sites More sharing options...
Zs-ondabrain Posted December 20, 2006 Share #8 Posted December 20, 2006 Those are all fine and dandy but here's one more....When you weld the holes, place a copper plate (available at most welding supply shops) behind the hole before you weld. The weld does not stick to the copper and the copper absorbs the heat. Make sure to spead out your welds, do a weld here, then over there, then come back over here, then go somewhere else. The heat has a lot less chance of warping the metal.take your time and you should be fine.Dave. Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193181 Share on other sites More sharing options...
e_racer1999 Posted December 20, 2006 Share #9 Posted December 20, 2006 not to concerned about the paint at this point, its going to be completely redone anyways when this is done....so im guessin that after the holes are welded its not gonna be all smooth and flush with the rest of the sheet metal, so how do i smooth it out so it is?just pick up a grinder and have a go! Link to comment https://www.classiczcars.com/topic/22689-couple-question/#findComment-193191 Share on other sites More sharing options...
