i have been sorting parts when i can. i have a ton of crap.
first the parts car is a early 73, with very early 4 screw su's( no tabs).
i began pulling it apart last thursday.( i only get a few hours a week right now to do this. damn its cold here now)
i have tons of distributors. every kind. every year i think.
15 5speed trans from all years.( i will get the exact model numbers soon)
i have a box of fans. i dont know why. but i do.
at least 15 280z ecu's.
lots of marker lights.
several center consoles in good to excellent shape.
i have a set of 82 zx wheels. with center caps and lug nuts. nice shape.
oh, i have a very cool jdm header. came off a 2.0 fairlady. dual outlet flange right off the header. it also has the mid pipe.
6 r200 diffs.
2 pair of zxt cv axles.
lots of front and rear bumpers from 70-73. some in ok shape some in good shape.
5 or 6 sets of early su carbs. at least 5 or 6.
a couple of su manifolds. i have both 33 and 46.
4 or 5 heads.
8 clocks. form various years.
lots of gauges.(speedo, tach, amp/volt, fuel, oil, temp)
3 pair of 70-73 tail light trim panels.
a couple of 280 tail lights.
lots of starters.
lots of alternators.
about amillion wiper arms.
1 perfect 280zx pass fender and headlight bucket.
lots of various interior trim pieces.
1 decent pair of red door panels.(faded, no holes, only very minor sun cracks around the lock pulls.)
1 very nice 70 fuel door with latch.
lots of original hubcaps(no center emblems though)
2 pair of zx t-tops.
and thats just what i can remember off of the top of my drunken head.
i havent gone through most of it. and i have even started working a car yet.
although i think the cars will go up for sale locally( i can get more money that way. but dont worry, no punk 16 yr old dumbass will get one)
as i clean stuff up, i will post it here. or ebay.
well, i need another beer. so, good night.
tony
https://www.classiczcars.com/topic/22723-zs-anyone/?page=2#findComment-196445
ok, i went through a few more boxes.
i found another 72 center console in pretty good shape. has a small broken chip around one of the rear mounting screw holes but not broken anywhere eles.
i have at least 2 72-73 center console fuse covers( the part with the def switch) in really good shape.
2 perfect fuse blocks with covers(72-73 i think) and 1 with a small chip on the cover(its not visible when on the fuse block)
1 perfect 70 fuel door with latch
1 perfect 71-78 fuel door.
1 complete heater control panel. no cracks, not broken. the chrome is faded and only has 1 small spot where its peeling(on the very bottom where i scraped on the shifter while taking it out,smacks self).
very clean datsun 8 track player. has the screws and mounting bracket. the wires are still there but were cut some time ago. this mounts in the glove box and i have no way to test as i have never even seen an 8 track tape.
i have a box full of 280 heater vent panels. from great to good shape.
3 e 12-80 distributors. they need cleaned up, but they should work just fine.
1 very nice set of early su's. 4 screw, no tabs. the entire manifold, balance tube,linkage and carbs are still assembled and fairly clean. i will shine these up as much i can.( i dont remember which manifold it is)
a few nice ashtrays and covers.
a nice orginal wood steering wheel.
1 nice black 1/4 glass trim panel.
lots of interior tail lamp trim pieces.
complete e88 head, externally oilled cam.
1 good pass door. only minor surface rust.
lots of drive shafts.
1 fiberglass pass headlamp bucket(sugar scoop). has all 3 studs. have 1 more but its missing 1 stud.
there will be more to come.
as i get each piece cleaned up i will put them in the classified section. but if you see something you need, pm me and i will get you some pics.
and i am always open to trade. even with all this stuff, i still need some things myself.
thanks
tony
https://www.classiczcars.com/topic/22723-zs-anyone/?page=2#findComment-197298
  • 1 year later...
  • 7 months later...
