jimbo99 Posted December 25, 2006 Share #1 Posted December 25, 2006 I'm hoping someone can help me out. I'm rebuilding an original intake manifold tuna cans and all for my 260's L26 and I'm stuck. Trying to find a complete or a P/N for a small section of engine harness that connects the EGR Solenoid, Throttle Opener solenoid to distributor. I'll describe it the best I can, two wires, a green/white strip to EGR solenoid w/male bullet connector and black/white strip Throttle Opener solenoid w/male bullet both terminate in a two pole male connect that I believe connect to a female connector by the distributer.Merry Christmas and a Happy New YearThanks,Jim1974 260Z - 302 Leaf Green Metallic/ Black RLS30-020697 (01/74) Link to comment https://www.classiczcars.com/topic/22750-stuck-carb-electrical-harness/ Share on other sites More sharing options...
beezee Posted December 25, 2006 Share #2 Posted December 25, 2006 Jim,I just posted complete harness part #,s front to back in the consule harnes post.I have 2 complete 260 under hood wire harnesses 1 correctly dated removed from 1/74 car. The connecters for the EGR ,throttle and distributer are part of the main engine room harness.Diagram BE144 shows connecters in 74 260 service manual. Maybe someone can scan and post Jim the vin on the 01-260 is RLS30-021428 Link to comment https://www.classiczcars.com/topic/22750-stuck-carb-electrical-harness/#findComment-193789 Share on other sites More sharing options...
JLPurcell Posted December 25, 2006 Share #3 Posted December 25, 2006 Could it be the E.G.I. Sub Harness # 24079-N4203? Link to comment https://www.classiczcars.com/topic/22750-stuck-carb-electrical-harness/#findComment-193790 Share on other sites More sharing options...
beezee Posted December 25, 2006 Share #4 Posted December 25, 2006 The green-yellow female plug to EGR solenoid The black-yellow female to throttle opener solenoid,black and green 2 wire female to water temp switch,yellow-white to thermal transmiter Distributer is green-red green-white,for man. trans Link to comment https://www.classiczcars.com/topic/22750-stuck-carb-electrical-harness/#findComment-193793 Share on other sites More sharing options...
jimbo99 Posted December 26, 2006 Author Share #5 Posted December 26, 2006 BeeZee Got the 260 SM let me look it up just got back into town thanks for the info Thanks for the info everyone. Jim BeeZEE Looked at Diagram BE144 and now see how the connecters for the EGR ,throttle and distributer are part of the main engine room harness. It looks like people just snipe them off when they remove the stock intake. or loop them and tape them over. I'll have to see on my engine room harness. I see that I was wrong about the male bullet connectors, must of been to much holiday cheer or staring at those solenoids to long. Link to comment https://www.classiczcars.com/topic/22750-stuck-carb-electrical-harness/#findComment-193834 Share on other sites More sharing options...
