red_dog007 Posted January 25, 2007 Share #1 Posted January 25, 2007 In the Black Dragon Auto mag, are the crossed-drilled disc brakes any good and worth the extra few dollars? I think $160 for a pair. Or should I just go with the standard brakes that Black Dragon offers?My friend told me to not get aftermarket cross-drilled brakes and they crack, and I was not sure if those brakes are aftermarket cross-drilled or not.Brakes are almost out and I found that out the hard way. :surprised Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/ Share on other sites More sharing options...
Marty Rogan Posted January 25, 2007 Share #2 Posted January 25, 2007 Cross drilled brakes do tend to crack. And if you intend to put the car on the track, where they build excessive heat, they WILL crack and could break apart. If you need the extra cooling, the better choice would be to do the Toyota 4x4 brake conversion with the 300ZX vented rotors.My two centsMarty Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-196839 Share on other sites More sharing options...
red_dog007 Posted January 25, 2007 Author Share #3 Posted January 25, 2007 Screw doing that. I think that will just stick with the non-drilled brakes instead. Saves me $80 anywho! :-) Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-196854 Share on other sites More sharing options...
240ZX Posted January 25, 2007 Share #4 Posted January 25, 2007 Screw doing that. I think that will just stick with the non-drilled brakes instead. Saves me $80 anywho! :-)For a street driven car you'll be just fine! However, do install good HP type street pads for the best results.Tom Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-196855 Share on other sites More sharing options...
ktm Posted January 25, 2007 Share #5 Posted January 25, 2007 By HP type Tom means Hawk HP pads (big assumption, as he may just mean high performance) . A properly working stock brake system with a good brake pad are more than sufficient for street use. When I refurbished my entire front end, I opted for Powerslot rotors, Hawk HP pads and SS brake lines. Now, I am eternally grateful for locking seltbelts whenever I get hard on my brakes. Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-196885 Share on other sites More sharing options...
240ZX Posted January 25, 2007 Share #6 Posted January 25, 2007 By HP type Tom means Hawk HP pads (big assumption, as he may just mean high performance) . A properly working stock brake system with a good brake pad are more than sufficient for street use. When I refurbished my entire front end, I opted for Powerslot rotors, Hawk HP pads and SS brake lines. Now, I am eternally grateful for locking seltbelts whenever I get hard on my brakes. Thanks Bo, you are correct on your assumption. I just happen to have the slotted rotors, SS lines, and HP pads as well......sure do work really well!!! Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-196900 Share on other sites More sharing options...
sleepyzzz Posted February 22, 2007 Share #7 Posted February 22, 2007 Cross drilled brakes do tend to crack. And if you intend to put the car on the track, where they build excessive heat, they WILL crack and could break apart. If you need the extra cooling, the better choice would be to do the Toyota 4x4 brake conversion with the 300ZX vented rotors.My two centsMartynot trying to hijack the thread here, but i am trying to get a '74 260 back on the road, and i wonder if this set up will work for mine?also, what year Toyota calipers to buy? will i have to do any major changes on my 260 to make this work?thanks for any help Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-200215 Share on other sites More sharing options...
=Enigma= Posted February 23, 2007 Share #8 Posted February 23, 2007 also, what year Toyota calipers to buy? will i have to do any major changes on my 260 to make this work?thanks for any helpThis topic has been covered ad nauseam here. A simple search could find you more than you wanted to know, but you can get the same by going here: http://forums.hybridz.org/showthread.php?t=103767orHere: http://forums.hybridz.org/showthread.php?t=104735... Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-200291 Share on other sites More sharing options...
sleepyzzz Posted February 23, 2007 Share #9 Posted February 23, 2007 yes i didn't try searching the forum before asking, my bad.thanks for the link though Link to comment https://www.classiczcars.com/topic/23064-brakes-brakes-brakes-and-more-brakes/#findComment-200313 Share on other sites More sharing options...
