Jon has a good point. I am doing the T-5 swap but it is more for the fact that I know the tranny has only 60k miles on it and worked perfectly. It definitely more work, more weight,better performance?? I got the driveshaft with mine but have to shorten it.
Maybe better to spend a little more to find a good nissan trans that is a easier bolt up with a better ratios for a N/A motor. Definetly do the research!!
https://www.classiczcars.com/topic/23173-t5-swap/#findComment-198687
