Hey all,
I am looking at the Konig 'Netz' 17x7 Wheel that is designed to fit the '72.
This car is dropped about 1-2 inches from what I can tell.
Are these gonna fit with no mods to clear the sheet metal, espically when working the car?
I love the look of these...
~Brian
https://www.classiczcars.com/topic/23379-konig-17s-question/
I made a mistake. The rims you are talking about will need spacers.
I was thinking of the two new rims that Konig makes for the early Z's. One comes in 15x7 and the other comes in 15x7 and 16x7. Both have a "0" offset. One is called the Maxxim 4 Play and the other is the Maxxim Screech. Sorry about that.
Spacers are ok to use as well. Modern Motorsports makes a very good set.
I appreciate the advice Sir...
And by spacers you mean the adaptors needed for the 5 lug, correct?
Thanks again...
The spacers are similar to the 5 lug adapters, but don't change the bolt pattern or number of lugs. They are designed to allow the use of commonly available 4-4.5 FWD wheels (a la Honda) on older RWD cars.
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
