how can i make my 78 280z auto, run a little quicker with out engine swap or turbo, turbo will come but not right know. everything is pretty much except for a little intake and a DYNOMAX exhaust system. they came with the car. it run real great and has less 100,000 miles on it, all for 500$. I have money save for performance parts but i dont know were to start. need help !
https://www.classiczcars.com/topic/23383-more-horses/
I'm in the exact same position as you. Exhaust, intake but my my car is a 5 speed. I've decided to go with the turbo swap, so i'm not planning on doing anything until then. Right now, you could go for higher gear ratio in the rear end and perhaps and maybe a header if you plan on keeping your engine for a while before you do the turbo swap.
https://www.classiczcars.com/topic/23383-more-horses/#findComment-200117
how can i make my 78 280z auto, run a little quicker with out engine swap or turbo, turbo will come but not right know. everything is pretty much except for a little intake and a DYNOMAX exhaust system. they came with the car. it run real great and has less 100,000 miles on it, all for 500$. I have money save for performance parts but i don't know were to start. need help !
One thing you could do is to change diff to a LOWER gear ratio. You have 3.54s now , 3.70s will give you more off the line but any lower than stock , will lower your top end. 3.70s are from a '79 2 + 2 ZX and is a R-200 diff. You have a R-180 I believe , so you would need the moustache bar also . The R-200 is a stronger diff. . This is about the least expensive of a mod you can do that will yield more performance. I did this in my Z and it does make a difference . Gary
https://www.classiczcars.com/topic/23383-more-horses/#findComment-200148
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
