I just recently asked if anyone had any information on a N47 intake manifold that had the heat shield cast as part of the manidfold. Upon further inspection of it today I was able to see that was not a heat shield but a webbing between the manifold inlets. At this point I'm guessing this is a turbo intake manifold. Am I guessing right?
https://www.classiczcars.com/topic/23399-n47-intake-manifold-correction/
  • 3 months later...
My 77 280Z and my 79 280ZX spare motor both have N47 heads. The one on IN my car does not have the webbing and the one on the 79 motor does. Of coarse neither is turbo, so I think the webbing means its off a 280ZX unless the 78 had webbing too.
webbing is on the later manifolds (with egr?)
TB = throttle body
plenum = tubes that go from the "log" of the manifold to the ports on the head. the "fingers" of the manifold. size of plenum refers to the area and flow inside of the fingers
