ZsRUSTIN Posted February 26, 2007 Share #13 Posted February 26, 2007 I installed the 4X4 calipers last year and also had trouble bleeding them. I had the same symptoms as you do. Hard pedal, no braking action. The problem was I installed aftwermarket braided S/S lines from M/S. The lines were a bit longer than the stock rubber lines causing the lines to loop up from the mounting point and back down to the caliper. They were about 5-6 inches above the caliper and would not allow the air to flush out . I finally removed the cailpers, holding them above the SS brake line while bleeding and that did the trick.Good luck Link to comment https://www.classiczcars.com/topic/23402-toyota-4x4-calipers/?page=2#findComment-200707 Share on other sites More sharing options...
Mpower280z Posted February 27, 2007 Author Share #14 Posted February 27, 2007 Too much snow, cant move the car into the garage tonight. Ill try again when its plowed better. And its so darn cold!!! Thats propane heater was my best investment in this project! Link to comment https://www.classiczcars.com/topic/23402-toyota-4x4-calipers/?page=2#findComment-200767 Share on other sites More sharing options...
