You have to drop the front and rear control arm brackets (the front bracket also has the front diff mount built in), but the arms themselves can stay on the car. The stock setup is really really badly designed for working on the diff. 510s and 280ZXs are MUCH easier.
Sorry, but there is no magic trick. It's just a PITA.
Or more simply put.....
Unbolt the driveline from the diff
Put a jack under the diff
Remove the 4 bolts holding the front diff mount
Remove the 2 big nuts that hold the diff to the mustache bar.
Remove the 4 nuts on each side of the diff holding the axles to the diff.
Slide the diff forward to get the two bolts to slide out of the mustache bar
Then lower the diff and pull it out from under the car.
Hmm... seems to me like the strap was in the way when I tried it the way you guys are describing. Maybe that has to do with poly mustache bar bushings or something. Then again it could be that I was doing it the hard(er) way for no good reason. Try it on a 510 or a ZX and I think you'll agree it's a bit more of a chore on the Z though.
The strap sits over the diff in case the front diff mounts breaks, As far as I know, It keeps the diff from hitting the body in case of mount failure.
I had to do it three times in a row so I got my instal and removal practice hours in. Now I may have to do it again when I get my Quaif ATB LSD diff rebuilt. Yah fun. NOT!!
Dave.
Dave.
Hey thanks! I was wondering what that strap was for!
I just swapped out my diff a couple of weeks ago. I did it just like Zs-ondabrain describes, axles, driveshaft, front mount and the two rear bolts. The only thing that was a real pain in the butt was getting at the driveshaft bolts.
I highly advise soaking down all the nuts and bolts with a good penetrating oil, preferably overnight or longer. It helps big time on old car nuts and bolts, nothing sucks worse than rounding off a really hard to get to nut or bolt. It can turn a fairly simple job into a nightmare from hell.
Two guys can remove and install a 240Z R180 diff in 30 minutes. One person can do it in 45 minutes to an hour. I've done it many times between sessions at a race track. Just sucks to have a hot diff laying on your chest as you wiggle out from under the car.
That paints a very funny picture in my mind. I've been there minus the heat, and did the same thing with the tranny. It's a bit heavier though and probably a lot more fun to watch. I'm glad nobody saw me. LOL
Hehe, I am my own tranny jack as well. I'm sure it's amusing for bystanders to watch...LOL
  • Who's Online   2 Members, 1 Anonymous, 1,383 Guests (See full list)
