So I was working on my wiring in the hatch today, when I pulled off the passengers side panel to reveal a plastic container with a bunch of hoses on it. Is that a charcoal canister?... should it be inside the passenger compartment?
Also, it appears my awesome previous owner has replaced a wheel stud with a standard one some time ago... .really annoying cause there is only one nut that must go on that stud.... What is the proper standard size to replace this.
Thanks,
Adam
by the way its my 71 240z
https://www.classiczcars.com/topic/23894-couple-odd-questions/
Thanks,
So just to get this right. That tank traps fumes allowing them to condense and go back into the tank?
This is the intent. to keep the fumes from the environment. If you know about the dangers of gasoline vapors , I am with you about the surprise to find it in the cabin. My self I did away with the thing altogether. Gary
  • Who's Online   1 Member, 0 Anonymous, 1,445 Guests (See full list)
