kats Posted June 16, 2017 Author Share #781 Posted June 16, 2017 (edited) A front cover of the S20, an unusual surface at top of the crank hole immediately caught my eyes, what is that? I am worrying about this cover has had repaired once before, has not it? As a reference, the third picture is my Z432's cover, I see a lot of casting small dents, and some rough surface at top of the crank hole. I need to look at it more carefully. Kats I see casting code, "9 6 6 20 " I think this means "1969 June 6th " , I do not know last "20" And the water pump, temporarily a GTR one is fitted. Edited June 16, 2017 by kats Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523252 Share on other sites More sharing options...
kats Posted June 16, 2017 Author Share #782 Posted June 16, 2017 Engine casting code, this thread is useful. Kats Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523256 Share on other sites More sharing options...
240260280 Posted June 16, 2017 Share #783 Posted June 16, 2017 Kats, I bet you could sell reproductions of that manual on Ebay for $100!! One way to raise funds for your race parts. 1 hour ago, kats said: I restored my race and rally manual , Terashima-san kindly gave me . I used the parts catalog' s picture. The Z432-R is exactly the same size picture of the manual. 2 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523257 Share on other sites More sharing options...
HS30-H Posted June 16, 2017 Share #784 Posted June 16, 2017 31 minutes ago, kats said: I see casting code, "9 6 6 20 " I think this means "1969 June 6th " , I do not know last "20" Kats, For reference, the 432-type S20 engine in my 432-R replica is stamped engine # S20-000877, and block casting numbers are 9 2 11 32: There was some suggestion that a batch of 432-type S20 engine blocks were cast at the same time as a batch of mid/late production PGC10 GT-R engine blocks, early in 1969. 2 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523258 Share on other sites More sharing options...
240260280 Posted June 17, 2017 Share #785 Posted June 17, 2017 If you need a better source see below 1 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523343 Share on other sites More sharing options...
Gav240z Posted June 18, 2017 Share #786 Posted June 18, 2017 That exact photo is my desktop wallpaper. 2 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523382 Share on other sites More sharing options...
kats Posted June 19, 2017 Author Share #787 Posted June 19, 2017 Blue, I will make thousands of copies for my project .Nice idea ! Kats Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523458 Share on other sites More sharing options...
kats Posted June 19, 2017 Author Share #788 Posted June 19, 2017 Hi Alan, your S20-000877 is also a good example, casting code is corresponding to the serial number. My 000884 is a bit later from yours , so that my casting code is showing bigger numbers than yours. Alan and anyone please help me to identify this LSD, do you think this is a correct R192 "4 pinion " / 2 way LSD ? I only see two round windows which are open for pinion shaft, these are supposed to be four , are not they? And two way or 1.5 way, it looks two way for me, but I am not for sure. I visited Matsui -san today, he said hello to you Alan, I wish I had plenty time to talk with Matsui-san , it was so fun. Kats Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523461 Share on other sites More sharing options...
kats Posted June 19, 2017 Author Share #789 Posted June 19, 2017 And this is my spare used R192 LSD two pinion type. Kats 1 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523462 Share on other sites More sharing options...
240260280 Posted June 20, 2017 Share #790 Posted June 20, 2017 This is the only R190 internal photo I have Kats: 1 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523480 Share on other sites More sharing options...
kats Posted June 20, 2017 Author Share #791 Posted June 20, 2017 (edited) Thank you Blue , that is a good picture. I have just taken this pictures under the sun, I see a teeth coming from the side which does not have a round window. According to a mechanic who has rebuilt a R192 four pinion LSD, 6 plates inside (4 plates of two pinion) makes the case thinner to have enlarged plates space. Do you agree this LSD is four pinion R192 ? Kats Edited June 20, 2017 by kats Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523486 Share on other sites More sharing options...
kats Posted June 20, 2017 Author Share #792 Posted June 20, 2017 You will say just open it and see what is in there. But I do not have tools to do that. I spent some hours looking at the LSD , And compared with the used differential in my hands. I found that they have different case, thickness is different each other. Normal two pinion LSD has thicker case than the other. You can see it from the pictures. If this is a NOS as the seller described and, fully functional like new , and if this is the real race option for GTR/ Z432-R, this four pinion R192 is the good finding. Kats 1 Link to comment https://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?page=66#findComment-523493 Share on other sites More sharing options...
