Kats,
There are similar shaped parts that are used on floor carpets on modern cars.  Not sure if you can find one similar but here is a Toyota  example:
I'll keep an eye out in hardware stores here.   1" top diameter and 1/2" shaft diameter.
Which style do you mostly like ?
Can I say I am doing my original style for the shift boot ?
My favorite is ‘ grommet on top ‘ style.
But I checked various pictures in brochures and old magazines, there are different kind of style.
Enjoy pictures.
Kats
Here is a rubber grommet that looks like it will work:
25mm diameter
12.5mm hole
Some car rubber detailer fluid will make it black and shiny.
https://www.ebay.com/itm/30-Rubber-Grommets-1-O-D-x-1-2-I-D-Hole-plus-or-minus/272214549916?hash=item3f6140659c:g:LJMAAOSwiylXBQk2
Thank you Blue, looks close to original.
Please see the picture , the left boot was a replica at the time Z432 restoration, I feel something different when I saw it. Now I got it, it has a grommet which came from a store!
I was asked which one do you want to put in your Z432, I said the right one please!
I want exact shape and look......
Kats
Edited by kats
Hi Kats,
Before I found my NOS shift boot shown below, I too was trying to find
the correct grommet in order to make a good reproduction boot.
You may want to contact Nix at www.240zrubberparts.com to see if
he could make this grommet.  I would think that a well reproduced
early shift boot would be very popular.
Dan
I've got two originals I could send you. One is softer than the other. I guess one hardened over time. The overall height is the same but one has a bigger gap than the other.20180127_193052.jpg
Sent from my [device_name] using http://Classic Zcar Club mobile
  • Thanks 1
Enjoy pictures.
Kats
Hi Kats, that photo is from HS30 00004, I have not seen the grommet top part of the boot on an AU market car. I have to say it's also my favorite style. I have attached a photo of the boot from HS30 00150 which I assumed was just missing the grommet, but now that I see the photo of HS30 00004's in more detail I'm inclined to think maybe it never came with that grommet?
Mike, I used to have a 16 track reel-to-reel machine and for cleaning the rubber on the pinch roller, Tascam sold lacquer thinner.  It softened the rubber while cleaning the iron oxide particles from its surface.
A rub with some lacquer thinner may help soften the grommet.
Edited by 240260280
I tried this (lacquer thinner) with a rock-hard side window bumper (the one that sits at the bottom-rear of the door).  It worked beautifully and I thought that I'd finally discovered the secret to rejuvenating all of the aging rubber parts on my car :victorious:.  Sadly, after 24 hours I found that the rubber had returned to its original, rock-hard state.:(
I've tried three different 'rubber and vinyl restoration' products to date and none of them have been effective in softening hardened rubber (or vinyl).
