23 hours ago, RIP260Z said:
Alan, in my CSP311 development uncovering, Nissan used A###X for their project codes (though the CSP didn't get one), e.g. A250X was an engine development of a SP311 engine and A550X was the still-born Nissan 2000GT. Was this carried on into the early, what would become the S30, which we see from the document as 270KK and changed (what I am asking is did it have an A###X first), or if I remember the CSP and S30 (for example) was designed under a different design studio's within Nissan? Thus, did each design studio/team have it's own code?
That's a good question, Ian.
I'm familiar with some of the project codes for the early to mid 60s period (such as the B680X) but I don't know much about the later ones and I wonder if there was some kind of re-arrangement or restructuring after the Nissan and Prince merger? I would imagine some kind of change being necessary, so I wonder if new project code systems were included in anything of that nature?
Something to look into for sure.
Here's my solution for replacing a PS30 Stock CDI with a Pertronix HP box, using the stock harness hookups.  It fit neatly on the existing bracket, with the aid of a pair of "hold-down" fender washers.
To get the Tach to work, I used an MSD Tach Adapter, as I could not get the Tach to respond to any alternate configurations using just the Pertronix setup alone.  The Tach loses accuracy as the RPMs increase, with a 700 RPM difference at red line (reading 6800 at 7500 RPM actual) but for now, that deficiency will have to suffice.
The other change I made is to remove the in-line coil resistor from the circuit, which is a simple matter of removing the electrical tape, removing the 8" wire connecting the resistor and the coil, and storing it for later use if needed.  I'll probably just mock-up two dummy wires and re-tape it to the main harness to give a stock appearance.  Of note, I think one can hookup the stock distributor trigger wires as well, but a prior owner had removed a good chunk of the wiring already, so I just used modern purple/green wires, bypassing the harness hookups.
edit: in thinking a little about this tonight, I may consider adding a jumper to "Ign Start" to the +12v switched input of the Pertronix, and monitor the results.  The car starts fine without this feature, but it's a little awkward, as some power is disabled during cranking (by the design of the ignition switch), which causes the Tach to jump twice.
Edited by xs10shl
2 hours ago, kats said:
Or like this , I am a bit fool for S20 even if it doesn’t sit on a car . Just looking at the machine, I can spend whole day of my life .
I can do the same thing when looking at the Rb26 in my Nissan Stagea (260rs). I have been fascinated with the RB26 for 20+ years and I just like looking at the engine in the bay at times.
Except Alan ,I don’t think we can explain about this engine. This is probably a pinnacle of existing, working of all the S20. I will report when this engine starts fire up in a car .
Kats
  • Like 3
  • Haha 1
51 minutes ago, siteunseen said:
I am positive it is a number 1 favorite song I would love but unfortunately I can not hear it where I live. :ermm:
Thank you Kats.
What ??? Why does YouTube  prohibit seeing American rock video in your American home ?
By the way , has Nissan USA ever used their song for TV commercial? I just imagine and it seems to me their name “ ZZ Top“ is suitable for selling Z cars .
Kats
Edited by kats
  • Who's Online   0 Members, 0 Anonymous, 785 Guests (See full list)
