3 hours ago, xs10shl said:
Great pictures, Alan.  I'm wondering if it's cost effective to press out a few parts to make a few of these headers.   The end result may look too modern, yet still potentially faithful to the original design.
I would like to say thank you Alan too , those are museum pieces, if not you , I don’t know who will be able to show those . We are lucky to be here .
Yes , those parts are usually hard to see .
Thanks !
Kats
I think that would be appropriate if the context suited, but definitely a niche interest. And - as is often the case with Works parts - something of a moving target in terms of evolution. Which version to replicate?
There's also a philosophical conflict between original parts and replica/re-popped parts when the originals were never sold to the general public in the first place. Can be something of a minefield. I'm still not sure what I think about all that...
  • Like 3
Today , I would like to present a little observation for the knobs .
 I am thinking to install a hand throttle lever which was pulled from a 1970 Z432 to my #2146. I found the lever is flattened around a symbol that would indicate a continuous, long term use by the owners . Or is that a natural thing from the beginning ?
Z432 , a S20 engine , most people preferred to start it without pulling a choke lever because of Mikuni carburetors .  Then it needs longer time to warm up than L-series engine , you will want to use a hand -throttle lever to ease your foot .
So , my guess is a hand - throttle lever on a Z432 is more likely to be premature faster than a choke lever on a Z432 .
On the other hand, L-Series SU carburetors need to be pulled a choke when it is started , and also used for warming up . Don’t need to use a hand - throttle for warming up . A choke lever for SU carburetors is always touched by hands ,might be premature much faster than a hand- throttle on the same  car .
The last picture shows a tape that shields a tiny screw in a hole when it is new.
Kats
Edited by kats
45 minutes ago, Mark Maras said:
I don't see much wear on the symbols that would indicate heavy usage. I think they were made that way.
Thank you Mark Maras ,
 Your comment gradually made me think the lever would be snapped off or the symbols would be erased before it is flattened .  Just a matter of molding? For 1972-73 levers , I saw similar variations on a surface around a symbols .
Kats
  • Who's Online   2 Members, 0 Anonymous, 1,434 Guests (See full list)
