There's a thought - what did the 240SX come with for a spare? That should work quite well, I should think.
Hi Arne, I have a 240SX for a daily driver. The spare is a space saver. I will have to check the fitment on a Z. I know the other 4 wheels wont fit a Z. Too much offset, hits the struts. But the space saver might fit.
FWIW,
Chris A.
https://www.classiczcars.com/topic/23910-sparetire/?page=3#findComment-205802
The can of air or Tire Inflator as Nissan calls it is still available. Though not the original, they work fine and I've bought two them over the years. Part number 999M1-300ZX. I'd rather have a new one than take my chances with a used one on eBay. The drawback to them might be the cost--about $70.
I've seen bottles in the (Walmart store) with tire slime (or something like that) in it and with some kind of inflator mechanism. Do you think that might work on a deflated spare in a pinch? It's much less than the dealer price, and available new, just not what came in the car when it was built.
I keep an electric inflator in the car nonetheless. :surprised
thx
https://www.classiczcars.com/topic/23910-sparetire/?page=3#findComment-205828
Nope. Remember that by trade I'm a server geek, so the second drive is internal as well, setup as a RAID1 mirrored pair. I've got external Firewire drives for the laptop backups.
Arne,
Seems I have heard this recently. Thanks for having lunch with me yesterday.
https://www.classiczcars.com/topic/23910-sparetire/?page=3#findComment-205836
The Nissan inflator is not a 'slime' type product. It's simply compressed air and is only desgned to inflate, not repair.
No, it's (the slime & air deal) not slime, but it's supposed to inflate your tire, and it's real cheap. Maybe themight work.
Hopefully, you're keeping the electrics on your car working, so you can trust the electric inflator will work when you need it.
thx
https://www.classiczcars.com/topic/23910-sparetire/?page=3#findComment-205838
Arne,
My pleasure, Bryan. Next time is on me.
Back on topic - I'm actually quite interested in hearing whether the 240SX spare will clear the bigger calipers. Since it is narrow, it should clear the struts, and has the right bolt pattern. If it clears larger calipers as well it would be the ideal solution for those of you with big brakes who want/need to carry a spare. Should be affordable at the local pick-n-pull.
https://www.classiczcars.com/topic/23910-sparetire/?page=3#findComment-205841
