red_dog007 Posted April 11, 2007 Share #1 Posted April 11, 2007 I found this kit on ebay for $588 w/ shipping. It does also include rotors for the front. Or I could get it for $443 w/ shipping instead without the front rotors. Does this kit include everything that I would need for a rear disc brake conversion? I was looking at getting drums, but to do brakes all around, it would only cost me between $100 and $200 extra just to go with the conversion kit for the rear instead of going with new drums.# (2) BRAND NEW FRONT 70-77 240Z,260Z, OR 280Z NON VENTED CROSS DRILLED/SLOTTED BRAKE ROTORS( SO NOW YOU CAN HAVE FRONT ROTORS TO MATCHED YOUR REAR ROTORS)# (2) BRAND NEW 280ZX REAR CROSS DRILLED/SLOTTED BRAKE ROTORS# (2) BRAND NEW FRONT STAINLESS STEEL BRAIDED BRAKE LINES# (2) BRAND NEW REAR STAINLEES STEEL BRAIDED BRAKE LINES# (2) REAR 6061 T-6 ALUMINUM REAR CALIPER ADAPTOR BRACKETS(WAY LIGHTER THEN THE HEAVY RUSTED STEEL BRACKETS# (2) USED,CLEANED,CHECKED,(BEAD BLASTED) & PAINTED W/ VHT HI-TEMP CALIPER PAINT# (1) SET OF REAR SEMI METELLIC BRAKE PADS# (1) SET OF BOLTS/LOCKING WASHERS & PICTURED INSTRUCTIONS FOR A STRAIGH BOLT-ON INSTALL.# (2) CNC MODIFIED REAR EMERGENCY BRAKE BRACKETS(NOT SOME HOME DEPOT BENT STEEL HERE FOLKS)# QUICK & EASY HASSLE FREE INSTALL,NO NEED TO REMOVE THE WHOLE REAR AXLE HUB,JUST YOUR REAR BRAKE DRUM BACKING PLATE# THIS KIT ALLOW YOU TO RETAIN YOUR STOCK EMERGENCY BRAKE CABLE# PLEASE NOTE 77-78 Zs MUST USE THE 240Z EMERGENCY BRAKE CABLES# PLEASE INDICATE THE YEAR OF YOUR Z AT END OF AUCTIONI am hopefully going to place an order for this in the next two weeks or so and start working on my Z again! Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/ Share on other sites More sharing options...
Marty Rogan Posted April 11, 2007 Share #2 Posted April 11, 2007 I am not familiar with that kit, however, I have a question on the intended use for your car first. Will this car be driven on the street or on the track? For a street car, the kit should be fine. However, for a track car you could do better. I would go with vented disk in the front. Definitely stay away from slotted and cross drilled rotors. Under the extreme heat generated at the track, the rotors can crack. I saw one case on a Z06 Vette, where the rotor actually exploded when he was going into the braking zone. It pulled the car into a wall and scattered bits and pieces of the car all throughout the corner. The carnage tore off the whole left side of the car. Luckily the driver got off with a mild concussion.Moral of the story, be sure the upgrade is right for the application.Marty Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205570 Share on other sites More sharing options...
nismospek Posted April 11, 2007 Share #3 Posted April 11, 2007 i think you can piece one together cheaper. msa sells the brake lines for roughly 50 bucks.the brake pads using rear 240sx calipers is another 50.you can get powerslot rotors for 50 bux each on summit racing.the rear brake brackets are 165 from modern motorsports.the only thing you would have to figure out is how to affix thee-brake and sourcing some used rear calipers from a 240sx. Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205594 Share on other sites More sharing options...
red_dog007 Posted April 11, 2007 Author Share #4 Posted April 11, 2007 Hmm.... I will keep looking around. Though I am looking for something that offers everything and is simple to bolt on. I want the lest amount of hassle. Like forgetting about a part that might be needed, and having to mod to get the rear disc conversion on.I might go to a local track once or twice a year maybe, but it is going to be a street car.I have heard that cross-drilled / slotted brakes can burst, but only if you track the car. For me, I won't be doing that much anyways. But cross-drilled / slotted brakes aren't necessary for me either. They are nice for show, but with the kind of rims that I have, you won't even be able to see them. I know that I would like some Brembo rotors though. I have only heard good things from them.I wouldn't mind getting this kit and using these rotors at first, because I would most likely get something different once they wear out. Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205598 Share on other sites More sharing options...
red_dog007 Posted April 13, 2007 Author Share #5 Posted April 13, 2007 How about this. I can't offered to do both at the same time, if I could I would, but what would be better to do first.Large 4 Piston Caliper kit in the front, or the rear disc conversion? Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205874 Share on other sites More sharing options...
Marty Rogan Posted April 13, 2007 Share #6 Posted April 13, 2007 If I were you, I would go with the Toyota 4x4 conversion for the front, with braided brake lines. Most of the braking is done up front anyway. The rear drums are adequate even at the track. I have used that set up with the vented rotors at the track for 3-4 years with outstanding results. The vented rotor set up is very wide though, so it may not fit under your wheels, depending on what you have. I know they fit under Panasports.The pads also make a big difference. I have been using Axxis Utltimate, a Kevlar/ceramic combination.Marty Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205880 Share on other sites More sharing options...
red_dog007 Posted April 13, 2007 Author Share #7 Posted April 13, 2007 So then something like this?http://autozone.com/R,APP989138/vehicleId,1698601/initialAction,partProductDetail/store,76/partType,00767/shopping/partProductDetail.htmand then pads like yours?So I am going to have to worry about this clearing and might have to tweak them a bit?The kit at the Z store, that though is just a bolt on with no modifying? Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205883 Share on other sites More sharing options...
Marty Rogan Posted April 13, 2007 Share #8 Posted April 13, 2007 The Autozone link does not work.The Z Store kit appears to be the non-vented rotor set up, which is not as wide as the vented rotor calipers. You have not said what wheels you do have have. All I can tell you is that if you go with the vented calipers (wide ones) and have wheels with a flat center section, they will rub. The Panasports cleared because the spokes bow outward. Rewinds also rub, but you can grind down the caliper to gain enough clearance.Good luck!Marty Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205884 Share on other sites More sharing options...
hls30.com Posted April 13, 2007 Share #9 Posted April 13, 2007 The Autozone link worked for me, you are looking for the S12 (nonvented upgrade) caliper(in the link), or the S12W (vented upgrade) caliper.Will Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205890 Share on other sites More sharing options...
red_dog007 Posted April 13, 2007 Author Share #10 Posted April 13, 2007 I am not sure what kind they are, but these are the rims that I got. They sound a bit like your description. Link to comment https://www.classiczcars.com/topic/23918-brake-conversion-kit-this-all-i-need/#findComment-205896 Share on other sites More sharing options...
