The number stampings are the same size, geezer. The blocks were stamped, evidently, with individual dies and they don't line up very well. I think that is what you are seeing. The firewall numbers usually line up much better. I'm surprised to see a VIN this high with a November manufacturing date. 26th is November. But I think she was pulled out of line for a new engine. Her engine # is 2338. 27th, on the other hand, is engine # 2162 and she is an October car.
Well it seems that #51 & #305 are now also available. See the 16th. post on this thread @ zcar.com.
http://www.zcar.com/forums/read.php?f=4&i=331804&t=331804
Quote....
"Aloha!
well, I have 2 1969's, and it's time for them to go. I'm not going to restore them.
Well, if anyone wants #51 or #305, They are now available. 51 is hunter green with black, and 305 is blue/blue Both in need of restorations. both numbers matching.
I have about 20 other 240's (1970-72) For parts and whole cars, as well as a 1975 Fairlady 2+2 RHD, but I think i have a home for the RHD.
Cheers!!
Charlie"
QUOTE]
#51 was recently posted for sale on the LA craigslist and mentioned in this thread.
http://www.classiczcars.com/forums/showthread.php?t=25547&highlight=51
I think they're confusing the air pump with an AC unit since it's diaplayed so prominently. I can't see any other reason to show that.
I agree. I don't see anything on the car that would indicate Dealer Installed A/C.
I had #357 recorded for several years...as the seller said, first in N.C. in the Winston-Salem area, then later reported in N.Y.
Is it possible that the Door and Engine Tags were simply stamped wrong at the Factory? Or perhaps the Vin's were stamped first into the Data Tags, then the wrong set was selected, stamped with the correct engine number and put in the car?
So far we have no reports of #359 being Found... I wonder if the data tags on that car would show #357....
Interesting car none the less...
FWIW,
Carl B.
Oh.. now I note the "Dryer" on the inner-fender....da...
I ask the seller a question about the data tags - he assures me that it's just bad pictures and in fact the numbers are all 357. I suggested he take the engine data tag out - clean it - lay it flat and take new pictures. Also to take clear pictures of the drivers door jam data tag. We'll see what happens...
FWIW,
Carl B.
  • Who's Online   0 Members, 0 Anonymous, 1,210 Guests (See full list)
