Any autoparts store like AutoZone carries these. You will have to offset it so it doesn't interfere with the crank pulley. Expect to pay around $50-70 for a 10-12" fan. Or you can visit Racer Parts Wholesale or call them at 800-397-7815. They sell two varieties.
https://www.classiczcars.com/topic/2405-radiator/#findComment-11338
You will feel A diff. when pull the fan from the waterpump. The one thing you could do is buy 2 elec. fans. Use one as you where going too. Then put the other one on the front side as A pusher. You will be shocked at how much cooler your Z will run.
Just make sure you cross over the + and - wires on the outside fan so the fan runs as A pusher.
https://www.classiczcars.com/topic/2405-radiator/#findComment-11437
  • Who's Online   1 Member, 0 Anonymous, 946 Guests (See full list)
