would this battery box be OK for racing (SCCA/maybe drag)?
This was taken from The BSP rules.
15.9 PARA C
C. Relocation of the battery or batteries is permitted but not into the
passenger compartment. If the battery is relocated and the original
battery tray can be removed by simply unbolting it, the tray
may be removed, or relocated with the battery. Holes may be
drilled for mounting or passage of cables. Longer cables may be
substituted to permit relocation. The number of battery or batteries
may not be changed from stock. The area behind the
rearmost seat is not considered to be within the passenger compartment.
The area under the rearmost seat is considered to be
This was taken from Page 28
15) Any wet-cell battery moved from the manufacturer’s original
location shall be in a non-conductive marine-type container or
equivalent, and the hot terminal shall be insulated. All batteries
(on-board power supplies) shall be attached securely to the
frame or chassis structure independent of the marine-type
container. NOTE: This will allow the use of gel cell or dry
cell (AGM) batteries without a non-conductive marine-type
container where applicable.
Hope that helps
Eric
  • Who's Online   2 Members, 0 Anonymous, 1,518 Guests (See full list)
