MRTOOTH Posted July 26, 2002 Share #1 Posted July 26, 2002 On my 75' 280 Z my oil pressure/tempature gauge does not work In the Hayes manual it says that the instrument voltage regulator could be bad. Does such a part exist? If it does, where is it, and could that be the problem? If it is not what can it be? Jeff Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/ Share on other sites More sharing options...
skip260z Posted July 26, 2002 Share #2 Posted July 26, 2002 Faulty oil senders are commen problem. Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11383 Share on other sites More sharing options...
MRTOOTH Posted July 26, 2002 Author Share #3 Posted July 26, 2002 Both sides don't work. Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11402 Share on other sites More sharing options...
EScanlon Posted July 26, 2002 Share #4 Posted July 26, 2002 In the KISS principle method:Have you checked to make sure that the unit is plugged into the wire harness? Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11414 Share on other sites More sharing options...
carguyinok Posted July 27, 2002 Share #5 Posted July 27, 2002 Before going hunting around inside your dash. Have you looked under the hood? The 2 you are talking about are very easy too bump off or break. Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11423 Share on other sites More sharing options...
MRTOOTH Posted July 27, 2002 Author Share #6 Posted July 27, 2002 Sometimes it moves then 10 sec later they die. :dead: Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11427 Share on other sites More sharing options...
carguyinok Posted July 27, 2002 Share #7 Posted July 27, 2002 (Sometimes it moves then 10 sec later they die) it & they ? They bolth come on and go out at the same time? Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11428 Share on other sites More sharing options...
CoastGuardZ Posted July 27, 2002 Share #8 Posted July 27, 2002 The very simple method of troubleshooting. "Good in, Bad out you've found the culpritt" I'm not yet an owner, but I am an Electronics Tech. Granted, $50,000 radars aren't auto gauges but they're pretty close. What's the one thing they have in common? A. power? B. are they in the same cluster? I don't know If they are ( If they're hooked up properly the chances of both senders being bad are slim. Most likely the Cluster should be replaced. The Gauge Voltage Regulator that the Haynes manual is refering to is more than likely in the cluster. If I couldn't be any farther off even if I lived in a closet let me know. The two most common problems on our boats are A. It's not plugged in and B. Grounding, you've got to have a good chassis ground. Happy hunting and good luck!!! :cross-eye Link to comment https://www.classiczcars.com/topic/2414-gauge-not-working-whats-wrong/#findComment-11429 Share on other sites More sharing options...
