anthony280z Posted May 1, 2007 Share #1 Posted May 1, 2007 what oil is best for 78 280z. it has over 100,000 miles. what oil do you guys use. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/ Share on other sites More sharing options...
ChrisA Posted May 1, 2007 Share #2 Posted May 1, 2007 Castrol 10W-30! What oil are you currently using? Keep using it and don't switch. $.02Chris A. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207926 Share on other sites More sharing options...
CoastGuardZ Posted May 1, 2007 Share #3 Posted May 1, 2007 Castrol 10W-30! What oil are you currently using? Keep using it and don't switch. $.02Chris A.My thoughts exactly!The oil question will typically get as many different opinons as post replies... but in the case my take is identical to Chris's.Nate Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207932 Share on other sites More sharing options...
bpilati Posted May 1, 2007 Share #4 Posted May 1, 2007 I've found that running without oil has lightened my car up a bit, and I can really feel the performance improvement. My engine is a lot cleaner too. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207936 Share on other sites More sharing options...
CoastGuardZ Posted May 1, 2007 Share #5 Posted May 1, 2007 I've found that running without oil has lightened my car up a bit, and I can really feel the performance improvement. My engine is a lot cleaner too. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207937 Share on other sites More sharing options...
76Datsun280z Posted May 1, 2007 Share #6 Posted May 1, 2007 20w-50w Valvoline Synthetic is what I'm running. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207947 Share on other sites More sharing options...
350zx Posted May 1, 2007 Share #7 Posted May 1, 2007 ROFL yeah i like that no oil trick i think i'll use that 1! Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207950 Share on other sites More sharing options...
Cybidium Posted May 2, 2007 Share #8 Posted May 2, 2007 So, I took your guys advice. Drained the oil, put a new filter on and took it out for a spin. I don't know what happend but the engine won't turn over anymore. when I turn the key I just hear clicking. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207996 Share on other sites More sharing options...
hls30.com Posted May 2, 2007 Share #9 Posted May 2, 2007 Your problem isn't oil related, you let the car see how much money was in your wallet...and It won't move until you spend most of it on something for the car.Will Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-207998 Share on other sites More sharing options...
Cybidium Posted May 2, 2007 Share #10 Posted May 2, 2007 I just had to jump at the chance. 10w-30 is what I use out here in Cali, i'm also a fan of the synthetics. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-208000 Share on other sites More sharing options...
AndysPlit Posted May 4, 2007 Share #11 Posted May 4, 2007 I would suggest using a higher viscosity oil like 20W-50 since it's an older engine. If you can afford synthetic, even better. But for those of us that don't want to pay more than $20 for changing their own oil I would stick with Castrol, Valvoline, and even Quaker State to save a couple bucks. I use a Bosch oli filter. However, I'm not sure if it's any better than your typical Fram filter. Yeah, another great thing is to drive the car without the cap screwed onto the can cover. Did that once. hehehehe. j/k. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-208417 Share on other sites More sharing options...
240ZMan Posted May 4, 2007 Share #12 Posted May 4, 2007 As long as you're using a premium brand oil, I'd focus more on the filter. Here's a website that did some interesting experimenting with various filters.http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html#fram-tg8aIt's been around for a while, so I don't know if the current filters on your store's shelf are the same as in this test. Before reading this I used the Fran Extra Guard mainly because it was reasonably priced, readily available, and made by a reputable brand. But after reading this, I decided to move to the Tough Guard. I usually don't see much value in the "intermediate" sub-brands, but in this case, I think it makes sense to pay a little extra. Link to comment https://www.classiczcars.com/topic/24173-oil-recomendation/#findComment-208434 Share on other sites More sharing options...
