hi, i have a 73 datsun 240z and both of my turn signal don't work. i dont really know what's happening, because i replaced the switch with a new switch and they still don't work. i checked the fuse and it looks good. when i pull the hazel switch the both turn signals do flash as they should, so i think i might be electrical problem but not sure. thanks everyone in advance for all your help.
https://www.classiczcars.com/topic/24251-turn-signal-dont-work/
As far as 'not working'.
Do the lights not come on at all, or do they come on and not flash.
If they dont come on at all, you have a bad connection somewhere. If they just dont flash, you need a new relay. They cost like $5 at Canadian Tire, and are pretty easy to come by.
the light don't come on at all. no light show to both side of the signal. but the hazard lights do flash to both sides. if i have bad connection, where can it be the most common location? and again where is the signal light relay located? thanks again
For an early 73 look under dash behind the steering column, and look for a small cylinder that looks like a metal 35mm camera film canister with two wires attached...that is your relay. Easily obtained at your local parts store, although if you go to MSA or VB you can get one that has been matched for you.
Later 73, look on the passenger side-side foot panel and you'll see several film canister type items. The one that is a cylinder resembling an aluminum can is the one you want. Take note that may/should be two right in the same area, the second one is for the Hazard flashers (yes, they are separate).
However, do a simpler check first and have someone step on the brake and see if the brake lights go on or not. If they do NOT, then the wire is more upstream and into the turn signal switch. If they do, you've pretty much narrowed it down to the flasher or....the hazard switch. (Yes, this IS possible.)
E
Fairlday, I had that same problem not too long ago. Simply cleaning my connections and switch fixed it right up. If the connections are poor, there may be enough power to actuate the flasher when you headlights are off, but when they are on, your headlights might draw just enought to push it under the limit so they wont work. Now after saying that - it could also be that your relay is on its way out. I'd say to clean your connections and switch first, and if that fails to spend a couple bucks on a new relay.
