Flat... hummm
Well actually it is not flat... it curves over the body line of the Z - righ tto left. Front to Rear of course it follows the body line, so it sits at the angle it's supposed to. There are too flat spots if you will, in which studs are mounted - these go though the deck lid - and are secured by nuts from the underside.
Nonetheless - it's fiberglass - and you can easily cut/mold it any way you want...
FWIW,
Carl B.
Flat... hummm
FWIW,
Carl B.
Took the words right out of my mouth Carl....I'll second that thought regarding it being fiber glass and easily modified.
Tom
  • Who's Online   1 Member, 0 Anonymous, 1,513 Guests (See full list)
