waezsn Posted May 16, 2007 Share #1 Posted May 16, 2007 Im not sure if this was posted or not yet. But what are the differences between the years? From the 240z - 260z - 280z. Anyone have a list of what the changes were? And why do the 240z seem to be priced the highest? Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/ Share on other sites More sharing options...
MikeW Posted May 16, 2007 Share #2 Posted May 16, 2007 In the US the cars evolved over time. Changes were made to reduce emissions and improve safety in crashes. The improved emissions led to lower performance as did the extra weight of bigger bumpers and body reinforcements. Because of these factors the engine displacement was increased from 2.4 liters to 2.6 liters for the 260Z in 1974 and to 2.8 liters for the 280Z in 1975. Despite the extra horsepower from the bigger engines performance wasn't quite up to the earlier standard which is a big reason why the earlier cars are more desirable. Another reason is that people like the appearance of the smaller bumpers even if they aren't as safe. There were many small refinements throughout the years, often in the middle of a model year. I don't know of a comprehensive list of changes for all years. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209782 Share on other sites More sharing options...
sblake01 Posted May 16, 2007 Share #3 Posted May 16, 2007 This should get you started but there are other posts on the subject, many others.http://www.classiczcars.com/forums/showthread.php?t=8271&highlight=Differences+240Z+280Z Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209783 Share on other sites More sharing options...
EScanlon Posted May 16, 2007 Share #4 Posted May 16, 2007 And one of the more comprehensive links, which gets quoted very often:http://zhome.com/History/DesignChanges.htmE Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209797 Share on other sites More sharing options...
agemeansnothing Posted May 16, 2007 Share #5 Posted May 16, 2007 Ya there is a big difference in weight. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209799 Share on other sites More sharing options...
sblake01 Posted May 17, 2007 Share #6 Posted May 17, 2007 Also in age. Which does mean something. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209825 Share on other sites More sharing options...
waezsn Posted May 17, 2007 Author Share #7 Posted May 17, 2007 Were the bumpers the only things that added the most weight? The engine I am not so worried about because I will be swapping it with a SR20det. So the bumpers and the engine were only the big difference? The chassis are all the same am I correct? Can the bumpers off the 240z be placed on the 280z? Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209862 Share on other sites More sharing options...
Arne Posted May 17, 2007 Share #8 Posted May 17, 2007 Im not sure if this was posted or not yet. But what...Welcome to our site! This is one of the largest repositories of Z-car knowledge available anywhere, with over 13,000 registered users, but more importantly over 200,000 posts in over 24,000 threads. So in general, almost any question that you, as a new owner or owner to be might ask has already been addressed here. Most of them not once, but dozens of times. Your questions regarding differences between years, and also with retrofitting 240Z bumpers to a 280Z are examples of topics that have been discussed almost to death here.Your best bet on these basics is to learn to use the excellent search feature here. Try searching with several different combinations of words and phrases, the amount of data you can find that way boggles the mind.There are several reasons why you may get better results from a search than from a new post. For example, many of the long-time members get tired of answering the same questions over and over, so they may simply blow right past your questions. Also, many of the questions posted by new members concern items that are static. In other words, the answers to these questions don't change, they are still the same now as they were 5 or even 10 years ago. Your question on retrofitting bumpers is an excellent example of a static topic, as are putting 280Z engines in early cars, swapping to a 5 speed transmission, how to tune the early SU carbs, etc. The answers to these questions never change, so using a search there gives the advantage of seeing posts from many more people, rather than the few who might answer your question directly.And why do the 240z seem to be priced the highest?Simple economics. Supply and demand. The 240Zs are the oldest, and many have died from accidents and rust. So they are somewhat rare, yet are still in demand. So they are more expensive. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209865 Share on other sites More sharing options...
Fun_in_my_z Posted May 17, 2007 Share #9 Posted May 17, 2007 As Arne said do a search you will find what you need. Although we like hearing from new members as well Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209870 Share on other sites More sharing options...
=Enigma= Posted May 17, 2007 Share #10 Posted May 17, 2007 Also in age. Which does mean something.LMFAO!!!! You're killing me Stephen! Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-209876 Share on other sites More sharing options...
Panamared Posted May 19, 2007 Share #11 Posted May 19, 2007 I found this link. Here you can read about the differences between the years.http://images.google.com/imgres?imgurl=http://www.zclubhungary.hu/image/z_cars/tn1969_240Z_Silver_Front_Left.jpg&imgrefurl=http://www.zclubhungary.hu/EZcars.htm&h=134&w=200&sz=12&hl=en&start=242&um=1&tbnid=6CLRCjsXjr2PgM:&tbnh=70&tbnw=104&prev=/images%3Fq%3Ddatsun%2B240z%26start%3D240%26ndsp%3D20%26svnum%3D10%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DNHope this helps. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-210070 Share on other sites More sharing options...
nwcubsman Posted May 19, 2007 Share #12 Posted May 19, 2007 I found this link. Here you can read about the differences between the years.http://images.google.com/imgres?imgurl=http://www.zclubhungary.hu/image/z_cars/tn1969_240Z_Silver_Front_Left.jpg&imgrefurl=http://www.zclubhungary.hu/EZcars.htm&h=134&w=200&sz=12&hl=en&start=242&um=1&tbnid=6CLRCjsXjr2PgM:&tbnh=70&tbnw=104&prev=/images%3Fq%3Ddatsun%2B240z%26start%3D240%26ndsp%3D20%26svnum%3D10%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DNHope this helps.Nice Link Juan, I had not seen this club site before. I appreciate it. Link to comment https://www.classiczcars.com/topic/24357-difference-between-the-years/#findComment-210096 Share on other sites More sharing options...
